Sony External bluetooth speaker not playing sound
    So, i got a speaker Sony rdp-x200ipn.
    I have an Acer Aspire E17
    I can connect my speaker to my laptop via bluetooth fine, when it's connected i can test the speaker and it makes the beep sound. When i start itunes, my speaker plays the sound fine, but when i search for example a youtube video I hear NO sound. When I turn of my speakers the sound is fine and plays from my computer and when I turn it on again no sound.
    Can anyone help me?
    Two possibilities. (1) The "Stereo Mix" is not set as the default recording device. (2) The Bluetooth is not set as the default playback device.
    It is set as my standard in my volume mixer, as it plays music from my itunes just fine. What do you mean by the second one?
    When you use Bluetooth, that should be set as the default audio playback device.
    Now the day after I tried it again ... After re-doing the whole process a few times yesterday I didn't got it to work, now I try it another time and it worked. Thanks for you help anyway!
A couple of days ago, I decided to move my tower from my desk to the floor. Everything was working beautifully up until then. I opened it up and removed some dust. After putting it back together, the monitor wouldn't register anything. I left it for a day, came back, and the monitor magically...
Hi, I'm using a laptop with Windows 8.1 x64 and I have the Intel Wireless-N 7260 WiFi card with Bluetooth 4.0. Last week I tried out a Bluetooth speaker of a friend, it was the BOSE Mini SoundLink. When I connected it to my laptop, the controller got installed automatically and it worked nice. ...
Can i do this from Windows 8? I've heard there might be a 2 second delay! Thanks
Hi, new to this forum. So I recently purchased an internal HDD, placed it inside a HDD enclosure. As soon as I switch it on, it causes a continuous buzzing/interference in the speakers- it seems to be worse when the volume is turned down. The casing is a metal material. I have another seagate...
Yesterday, I bought a pair of Samson Studio GT studio monitors. which connect to my computer via USB. However, I'm only getting sound out of one monitor/speaker, that would be the right side with the power cable. I've checked the speaker wires and made sure they were hooked up correctly for...
Solved External speaker fail in Sound & Audio
The internal speaker works fine, but when I plug in the external speaker, (speaker plug + USB) it seems to mute the whole system. Anyone else with the same issue?
I just set up win 8 on my computer and was going thru the process of connecting my bluetooth mouse and my bluetooth keyboard. My mouse connected automatically, no problems. When I went to connect my keyboard I got the usual prompt asking you to enter the code, but the code was not accepted no...
