External headset problems with Clevo W355SS
    Windows 8.1 Pro 64-Bit
    Hi,
    I have the Clevo W355SS laptop. The official site is: ??Clevo . I ordered from Logical Blue One: Logical Blue One - Horize W355SS Gaming Notebook
    I'm having a problem with getting external headsets to work correctly. The laptop has a mic and audio jack. The headset, Turtle Beach X12, is powered by USB and has a mic and audio plug.
    The problems:
    1. The microphone will not work at all. Only the laptop's internal mic will work.
    2. The audio received through the headset is off. For example, in a song, the voice will be softer than the background instrumentals when it shouldn't be.
    I have determined it is not the headset because it works fine on another desktop.
    I have determined it could be the audio drivers but I'm not getting any luck installing ones from the official site or from the disc the laptop came with.
    Any insight or help is appreciated.
    Thanks.
    This headset system, if not wired and set up correctly can be a problem. It requires USB power to operate. It has an adapter to connect to the PC's headphone and mic connections. Doublecheck that you have everything wired correctly.
    The headset comes wired with the adapter, so it does have power running through as the light turns on.
so i got an msi gaming z97 micro atx board, but on the io i cant find where the hell to plug in my headset.... there is a mic and the l-output and input well 3 inputs and 3 outputs. i checked the manual but it didnt say it. 56997
Logitec 960 USB Headset in Sound & Audio
Please could you help? If I unplug my headphones and plug them back in again the sound continues to come through the speakers and not the headset.The only way I can resolve it is to restart Firefox. I have posted in the Logitech support forum but no one replied. Thank you
Can't get headset to work in Sound & Audio
So today I got a new acer laptop with windows 8. The laptop only has one audio/microphone input in it. When I first plugged the headset microphone jack into the singular input, it asked what device it was. I selected headset and moved on. Later, I could not find my headset mic in my audio...
Cannot Remove BT Headset in Drivers & Hardware
I was trying to remove my BT headset from BT devices and now its stuck on "removing device"... won't remove...won't even let me connect the headset now :/ even tried removing them from device manager, after a the device appears again :/ the screenshot is attached
Hi there, I recently intalled windows 8 on my Clevo. And thing were going very well. Today suddently it presented me with a bsod. It's in portuguese... so I imagine it will be hard to find the problem... I guess... Thanks anyway!
I have been having problems with a USB 3.0 external drive. When I reboot Windows 8, the drive is not recognized each time, and I have to remove the USB plug and re-plug it to get the drive to be recognized. After that, it works fine, but I have to do this each time I reboot. Anyone had a...
No sound using 360 headset in Sound & Audio
I am using a turtle beach headset plugged in through my xbox 360 wired controller. The device displays in the sound area but does not produce any sound when i try and test it. It doesn't even act like the test is being sent to the device. The mic however does work just fine. Anybody have any...
