Lenovo G510 Mic problem
    I'm using Windows 8.1.The problem is my mic doesn't work i change it to speakers from listen but in recording it's still show defaut device.I was wondering why my mic is so low and finally find the problem but now this is another problem how to fix this.
    I found a way to fix it.You can close thread.
    Quote Originally Posted by vilivili View Post
    There's no closing the tread, just mark it solved but would be nice of you to share the solution you found, might be of use to somebody else.
lenovo easy camera driver problem in Drivers & Hardware
Hi friends I bought a new lenovo G500 note book, i5, 4GB ram with windows 8 but today when I click to camera tile it says this camera is not compatible wit this version of windows. I have tried driver update and some other settings but failed. please help me.
Hi! I can not connect my laptop to the internet neither through cable connection nor wi-fi. When I troubleshoot it, it shows two errors as below: There might be a problem with the driver for the Ethernet adapter There might be a problem with the driver for the Wi-Fi adapter After trying...
Solved Lenovo G580 audio problem in Sound & Audio
Hello. I have a Lenovo G580 with Windows 8. I have a weird problem with audio. If the default audio is set as internal speakers and I plug in my headphones the sound just keeps coming from the internal speakers. But if I set the headphones as default, I can switch between the speakers and...
Lenovo y50 Network Problem in Network & Sharing
Excuse my typing, on my phone ATM. I recently performed a downgrade on my Lenovo y50 laptop, and everything worked well in the end and Win7 Home Premium is up and running. I installed all the drivers for the laptop on Lenovo's website, but my WiFi remains unusable (tried direct line from router,...
I recently purchased a Lenovo G510 laptop with Windows 8.1. I've had only one major issue with it, where I can't use the AMD Radeon graphics which should be on my computer. When I load up Speccy, only the Intel HD Graphics 4600 shows up; the same happens when I look for the AMD card in Device...
Hi all. My Lenovo Twist (Ultrabook s230u) has ran into problems - and tries to run AutoRepair but gets hung up each time. Lenovo has instructions for creating a bootable USB to run UEFI diagnostics: Lenovo UEFI Diagnostics - Bootable USB (Create it on Windows OS) - Desktops / Notebooks /...
G510 issue in Drivers & Hardware
Ever since switching to AHCI mode, I've noticed that my keyboard has issues with the volume wheel not working properly. Also after setting up the LED lighting on the keyboard and a few restarts later, I've notice that when restarting my system the keyboard LED, blue in this case, will automatically...
