Lenovo G510 Mic problem
vilivili
I'm using Windows 8.1.The problem is my mic doesn't work i change it to speakers from listen but in recording it's still show defaut device.I was wondering why my mic is so low and finally find the problem but now this is another problem how to fix this.
    G510
I found a way to fix it.You can close thread.
There's no closing the tread, just mark it solved but would be nice of you to share the solution you found, might be of use to somebody else.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
