Audio Increasing on it's Own
    Hi Guys,
    First time posting in this forum but I've been a regular reader of this forum's contents.
    I have been having this issue lately where my volume automatically increases. I try to set at level 10-15 but windows automatically increases and when it reaches 100 the volume sign on the top left corner keeps showing, i.e., windows is still trying to increase the volume. I have tried every possible things to fix this but this keeps sticking. I have also selected do nothing in the communication tab.
    My system spec is:
    MSI Z97 GAMING 7 || Intel® Core™ i5-4690K (@ 4.4GHz) || Corsair H100i || EVGA GTX 780 Ti SC w/ ACX & Reference Cooling in SLI || G.Skill TridentX F3-2400C10D-16GTX (2 Kits) 4x8GB 2400MHz CL10 || Samsung 840 Pro 512GB x2 RAID0 || WD Caviar Black 1.5TB Docs & Storage || Corsair AX1200i || Coolermaster HAF-X Full Tower Case || Dell U3011 || Windows 8.1 Pro x64 with Updates
    Please help!!
    Screenshots:
    As you have a separate sound card (the SoundBlaster) did you disable the on-board (on the motherboard) sound in the BIOS? If not, that is the first step. The on-board needs to be disabled to prevent any possible conflicts.
    Also, what is listed in the Device Manger, Sound section?
    Yes, fireberd!! I have the HD Audio disabled at the BIOS. Kinda used to disabling that settings now, coz I've had a discreet sound card for a while now!! Any other suggestions to fix this!!! And BTW, I have the latest creative drivers installed that was released recently by creative for windows 8.1. The drivers is XFTI_PCDRV_L11_2_40_0008.exe the drivers were released on Mar 7, 2014. Heres the link:
    Creative Worldwide Support > PCI Express X-Fi Titanium
    In in the device manager, after the driver installation it's listed as Creative X-Fi or something of that sort. It's also got the nvidia hd audio which I've disabled.
    The NVIDIA audio is for HDMI audio only, it won't interfere or cause problems with PC audio.
    Look at what programs you have running, that uses or can affect audio (e.g. Skype) as one of these could be causing the problem.
I have poor vision and am struggling to customize Windows 8.1 so I can see it. My eyesight is corrected by glasses, but I see everything about 30% smaller than it is in real life (glasses prescription -9.5). I use a laptop all day for my work. Specifically, I need to increase the size of the...
Solved Paged Pool memory constantly increasing in Performance & Maintenance
Hi Everyone. I've been searching as much as i could here and there on the internet without any luck so i'm giving it a chance here if someone has an idea how to troubleshoot/investigate this. I'm Running Windows 8.1 Update 1 Enterprise. custom built machine : I7 4770K 32gb ram Samsung...
Increasing responsiveness of PC post-startup in Performance & Maintenance
Okay, so by reducing startup objects, windows can boot pretty quick, however immediately after seeing the desktop, whenever I try to do something like open a folder or open chrome, there is a slight delay as tray icons and desktop icons start appearing. So how do I minimise this delay so that as...
I'm needing some help on the opposite problem most people have. While most want the corner gestures disabled, I'm actually looking to increase the size. Long story short, I'm running an old touch screen in a mobile environment. And while I see great benefit to using Windows 8.1, I'm having...
Random BSODs with increasing frequency. in BSOD Crashes and Debugging
I have been experiencing bluescreens with increasing regularity. I've made sure all of my drivers are up to date. I've run dskchk, and done the windows memory test, neither of which have come up with anything. I am at a loss of where to go from here as these dmp files make no sense to me...
Increasing TTL for access point in Network & Sharing
This may be a little difficult to explain, but I'll try my best. I have an university connection, which has TTL set to 1. I made an Access Point with my WiFi in laptop, however, I think that the TTL may cause that the Internet connection on my devices which are connected to AP is not working. I...
Source: Increasing the app roaming limits
