Boosting sound over the default maximum
    Windows 7
    Hi, is there any wayto boost the sound volume in Windows 8 over the default maximum? I'm open tothird-party programs to help with this also.
    Canada
    If these are external speakers do they have their own volume control?
    Windows 7
    No they are not external speakers unfortunately.
    Canada
    I know of no way to boost the default maximum but purchasing eternal speakers is a option.
    Windows 7
    I'm in an environment where external speakers don't work, but headsets do. I'm actually using a headset right now and at the highest volume setting it has incremental improvement over the internal speakers, but still not at the level I'd like. I'm hoping there's a software solution that can boost the volume further.
    Canada
    The East Coast
    Windows 7 Pro x64 Windows 10 Pro x64 Build 9926
    VLC lets you raise the volume big time over windows, just click on it`s window when it`s open and use your mouse wheel
    VideoLAN - Official page for VLC media player, the Open Source video framework!
    N.Y.
    Windows 10 Pro 64bit
    gonna same idea no volume control within this third party software also ?
    The East Coast
    What ???
    Windows 8 Pro Retail
    Go to speaker properties and select tab enhancements and Loudness Equalization
Page 1 of 2 12 LastLast
I have a small video file made by a video camera while it was held by me. My voice is clearly audible, whereas the person yelling towards me from a few yards away is a much lower volume on the video. Anyone have suggestions for a good video editor that can boost the harder-to-hear portions of...
I have 2 USB sound bars connected to usb ports on my pc. Under sound settings I can only select one of the sound bars as my default speakers. Is there some way to select the second as well?
maximum brightness in Drivers & Hardware
hei, i've tried all solution that you give, but this is my problem (look at the picture)30323 30324 because this problem my screen set to maximum brightness and it is very uncomfortable for my eyes. how i can fix that? sorry for bad english
Maximum modern ui in Customization
Check out this project of mine with 263 icons modified to look more Metro LINK : MAXIMUM MODERN UI by ~nan0j0k3r on deviantART UPDATED LINKS MAXIMUM MODERN UI UPDATE 3/14/2013 by ~nan0j0k3r on deviantART and MAXIMUM MODERN UI BETA 1 (4/15/2013) by ~nan0j0k3r on deviantART
Hello, I am getting a random notification sound but no notifications are appearing in Windows 8. I have isolated it to be the default asterisk sound but nothing is plugged into my computer, not even the power cord, and I will still get the random sound. Any ideas? Thanks!
Read more at source: Are SSDs the new RAM for boosting system performance? | ZDNet
Title says it all. I've tried using 7 drivers, and XP drivers. The monitor is an HPvs17 flat panel monitor. The maximum resolution is 1280x1024 at 60Hz, and when I set it to that, it says out of range. Resetting the monitor to factory defaults doesn't work, and neither does using auto correct...
