Boosting sound over the default maximum
Ark
Hi, is there any wayto boost the sound volume in Windows 8 over the default maximum? I'm open tothird-party programs to help with this also.
    Windows 7
If these are external speakers do they have their own volume control?
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    NIVDIA GeForce GT 520
    Realtek ALC656GR CODEC
    Samsung SyncMaster S22B350
    1920X1080 32 bit color
    Samsung 850 EVO SSD 500GB
    Logitech M510
I know of no way to boost the default maximum but purchasing eternal speakers is a option.
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    Logitech M510
I'm in an environment where external speakers don't work, but headsets do. I'm actually using a headset right now and at the highest volume setting it has incremental improvement over the internal speakers, but still not at the level I'd like. I'm hoping there's a software solution that can boost the volume further.
    Windows 7
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    Logitech M510
    Windows 7 Pro x64 Windows 10 Pro x64 Build 9926
    Gateway GT5404
    Intel Core 2 Duo E6700 @ 2.66 GHz
    Intel D945GCL
    4GB PC2 6400 @ 800 MHz CL 6-6-6-18
    MSI GTX660 TF3 2GB
    Realtek HD
    Gateway FPD1975W
    1440 x 900
    Samsung 850 EVO 120GB SSD / WD 500GB
    Corsair HX750
    OEM
    OEM
    Gateway KB-0401
    Gateway MOAKUO
    Verizon Quantum Gateway 60 / 60
    Chrome / IE11
    MSE / Defender / MBAM
gonna same idea no volume control within this third party software also ?
    Windows 10 Pro 64bit
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    AZZA Cosmas Black Gaming Case
    84mbps /94mbps
    Norton Security 2015
What ???
    Gateway GT5404
    Intel D945GCL
    MSI GTX660 TF3 2GB
    Realtek HD
    Gateway FPD1975W
    1440 x 900
    Corsair HX750
    OEM
    OEM
    Gateway KB-0401
    Gateway MOAKUO
    Chrome / IE11
Go to speaker properties and select tab enhancements and Loudness Equalization
    Windows 8 Pro Retail
    MSI GT70 2OD
    Intel i7-4700MQ
    Not sure, GT70 2OD's main board
    16GB DDR3
    intergrated Inteal HD 4600, dedicated GTX 780M
    Dynaudio/ Realtek HD Audio
    17.3" 1080P matte display
    Toshiba SSD 128GB, Seagate 750GB
    MSI
    Built in steelseries
    56 Mb down, 10 Mb up
    IE 11
    Windows defender and malware bytes
    Yes, it can easily play Crysis 3!
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
Sorry i meant isn't there a volume in this 3rd party software, i use PowerDVD has one, even sometimes volume not up in Media player.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
