Headset Microphone not working
    windows 8.1
    Hello Eightforums.
    Firstly, my problem is that my headset microphone is not working correctly. As my laptop (Lenovo g505s) only has 1 audio jack, but my headset has 2 cables (green and pink), i bought a 3.5mm headset splitter adapter that splits audio output to 3.5m headphone and 3.5 mic jack. Having plugged it in, I am getting both my internal microphone sounds along with my headset microphone sounds through my headset.
    This is what my volume mixer looks like right now: http://i.gyazo.com/6adf9c6e8ddf0f894ce152afc1d7a9dc.png
    My playback tab in sounds: http://i.gyazo.com/0af54f31a3290bc9acdfa1ea7fad50c6.png
    My recording tab in sounds: http://i.gyazo.com/0af54f31a3290bc9acdfa1ea7fad50c6.png
    My SmartAudio :
    http://i.gyazo.com/5f3d621863dff95de5c7459365ffa610.png
    http://i.gyazo.com/138a2a9314676735447d0b083c0522f2.png
    I am unsure what how to proceed to fixing this issue.
    Thanks,
    Poolwizard
    windows 8.1
    Oh, it seems the problem got solved.
    My solution i found on the internet was to go to device manager and then under sound, video and game controllers, i uninstalled the sound drivers. (in my case, AMD High Def Audio Device and Conexant Smart Audio HD)
    After both were uninstalled, I restarted my laptop. Then on boot up, the small speaker on bottom right on the desktop has a little red circle on it. I troubleshooted the problem (right click speaker, top option) and it installed something (i assume both the 2 sound drivers I had just uninstalled, since i just checked device manager after it had finished installing and both my previous sound drivers were present). And it seems to work now.
    I still don't entirely understand how it worked, but that was my solution.
So the other day i bought a Logitech for 15 and i get home to recorded my voice but my laptop wont pick up my headset..Like it knows its been plugged in etc and will even play sound through the headset but can seem to get it to pop up on my microphone bit! Could someone help me please?
Microphone not working in Sound & Audio
Hi, I have a Dell Dimension running Win 8.1 pro. Recently my microphone has stopped working. I have looked at other threads and none have helped. My mic does work with other computers but no with mine. When I tried to record my voice on many apps (Skype, sound recorder) but no luck. When I pull the...
I have a Creative Fatal1ty Gaming Headset , the audio work's but I cannot get the mic to work. I have a Creative soundblaster 5.1 live soundcard and a abit fatal1ty fp-in9 sli m/b. Audio works on both soundcard and on-board sound on the m/b , but not the mic .... I know some basics to...
Hello~ I was recording with my internal realtalk hd mic on my laptop, but it stops working everytime I plug in my head set. There's nothing special about this headset, and there's no microphone on it. Sadly, my RT mic does this with any headset I use. It's frustrating when I unplug my headset and...
Hallo, The microphone on this non-brand headset isn't working due to the microphone not showing up under the recording devices. Audio is working for the headset (and anything else that I plug in ), but not the microphone. The green bars do not go up in the audio manager either when I test the...
Microphone is not working in Sound & Audio
I am trying to record voice overs for videos I am making with a program called Pinnacle Studios 14. It's a little outdated but it gets the job done well. I am also running Windows 8 on a new computer. I am also using (or trying to use) a Logitech USB headset/microphone. The problem I am having is...
