No volume icon showing in taskbar
    Windows 8.1 update 1
    I have reset explorer.exe and it pops back, but when I restart my laptop it does not show up again.
    I have even gone into the registry and followed the instructions from this video on Youtube and it's still the same.
    Fix Volume Icon Missing from Taskbar Problem in Windows 8/7/Vista - YouTube
    Any ideas?
    Thanks
    According to the Dell downloads for the 15R SE, this has Conexant audio. Suggest you download and install the driver from Dell, as the first step.
    Product Support | Dell US
    It suddenly popped up.
    I restarted and it's popped up again.
    I don't know why it suddenly decided to appear.
    I haven't done anything different.
    Since its done it before, it may do it again. What do you have listed in the Device Manager, Sound section?
    Conexant SmartAudio HD - I have the latest driver for this aswell, which I downloaded from the Dell website, specifically for my model of laptop.
    Unless there is another later update that Dell are not showing?
    What else is listed? e.g. are there any "High Definition Audio" listed? Just trying to find out if there are others there that should not be there. If there are others, that should not be there, they could be causing conflicts.
    Under 'Audio inputs and outputs' there is:
    'internal microphone (Conexant SmartAudio HD)
    'speakers (Conexant SmartAudio HD).
    Under 'Sound,video and game controllers' there is:
    Intel Display audio
    Sounds correct, the Intel Display audio is for HDMI audio. However, the "Stereo Mix" should be set as the default recording device. That will allow whatever input (e.g. mic) to be heard/recorded. Also, if you ever want to record any audio from the internet you will need the Stereo Mix.
    It's not showing again!
    Look at what programs you have running when this happens, specifically programs that use audio. It may take a little time to see if one of those are causing it - stop a program from starting/running and then see if the icon goes missing. If the icon still goes missing, try a different program.
Page 1 of 2 12 LastLast
iPhone Device Icon not showing up in Drivers & Hardware
So, it used to be okay on Windows 7, but now the iPhone icon is not showing up in Windows Explorer or in "Devices and Printers". How can I fix that, since it bugs me very much... http://puu.sh/a6DEu/b1997a8497.png Picture of my computer with no iPhone image. http://puu.sh/a6DK0/db51078739.png...
Solved Power Icon and Log Off Icon not showing in Performance & Maintenance
47463 The icons on the start menu and login screen are missing. how do i solve this?
I Want Use Windows Mute Volume Icon for nircmd Command. Can I do That ? My New Multimedia Keyboard No Mute Volume Button :( http://i57.tinypic.com/35ndaa9.png Recommend for Icon ?
Hi, is there a weak that would allow me to mute the system volume by double clicking the microsoft speaker icon on the taskbar ?
I have created a shortcut icon which takes me directly to my Online Banking Login page. I would like to place this icon (an image of a padlock taken from windows icon cache) on the taskbar. My problem is, when I drag the icon to the taskbar a popup asks me if I want to 'Pin to Internet...
I am trying to copy files from my cpu using win 7 to a friends using win 8. hd shows up with the volume used but files are not viewable. tried to copy and past to a new folder saw all the music files as they were pasteing . after I opened the new folder some files were there about 2gig out of 414...
actually i dont know in which category i should post this threat. so i posted it in general category. i have installed Windows 8 on my notebook few days back. I didnt paid much attention in the starting but now it gives me trouble when my battery status is not being shown on the notification...
