Trying to connect Headset to TV Monitor Connected to PC
    Windows 8.1 Pro 64x
    I have been Google Searching like mad trying to figure out how to do this, is there anyway of doing it at all, so basically I want to connect my Headphones to my TV and use that as my speakers for both TV, Xbox, and PC as I run them all through the TV, my TV is a TEAC. So Please if anybody could help me on this, I would be a happy man.
    Regards,
    Raider2Knight.
    If your PC has an HDMI out, you can connect that to the TV. The TV would then act as the monitor for the PC and have the PC audio. If you can't do that or don't want to do that, you can connect the rear Speaker (GREEN jack) or the LINE OUT jack to the TV (providing the TV can handle just a separate audio source). Use a shielded audio cable, not a speaker or headset wire to connect between the PC and the TV. Also the distance (length of cable) could be an issue. Keep the length to about 25 ft or less to avoid potential signal and fidelity loss.
    Windows 8.1 Pro 64x
    I guess I'll have to try setting up the HDMI cables then. Thanks for your help mate
Hi All, After much trawling on the net, i have finally given in and am seeking direct help. When i choose the connection's icon from the task bar, to connect to wifi, the connection side bar appears for a brief instant and disappears. At the moment i can connect to the network in my home,...
My laptops screen resolution is 1366 x 768 and I plugged in a external monitor via hdmi and it's recommended resolution is 1920 x 1080. Everything on my monitor is too big for the screen and the taskbar is cut off along the bottom and when I go to full screen, stuff across the top is cut off.
Hi there, I have seen some posts on internet, concerning connecting an external CRT Monitor with a Laptop computer. They pretty much said that there might be a blue cable with, and one can use it to connect that monitor with laptop. Now I am confused that mine monitor has two cables; one of...
i just bought a dell xt2 on ebay it came with windows 8 pro. my problem is that it goes into limited connection every ten minutes, even when i am next to the router. the error i get when i trouble shoot is the Default gateway is not avaible. let me know if you need any more info.<br>
I recently purchased another monitor so I can run dual-monitors on my newly upgraded-to Windows 8 desktop. I set the monitor up last night, and I haven't had any major issues so far... One issue that I've run into, though, is the secondary monitor (regardless whether it's the monitor I owned first...
hi, i have an alienware m15x r2 which i recently upgraded to windows 8 through a clean install. everything works great except for the wireless, and i cannot for the life of me figure out whats run. ive tried about 10 different wifi points on campus and tried wirelessly tethering tommy phone and...
Hello guys, I have recently downloaded and installed the Win8 RP x64 in VirtualBox at no avail (insufficient resources), so I am trying the native installation now. I have successfully installed the win8 RP x64 on my external USB HDD Seagate GoFlex Desk (2TB) in its own partition with the help of...
