Headphones sound rubbish in laptop today
    Used my computer after work to listen to music with headphones in and it sounds rubbish, bearable but rubbish. I have Sennheiser headphones that usually sound fantastic, they still do sound fantastic on my phone listening to the same song on Spotify.
    Anyway, tried Spotify and YouTube and the music just sounds rubbish, kind of flat and no bass. Tried using the audio adjustments and it's not really made a difference. It was fine this morning.
    The laptop's built in speakers sound as bad as usual, better than the headphones though which isn't right at all.
    Really am stumped as to why this has happened.
    Assuming nothing has happened to the hardware from the last time you used it, if you have a System Restore point that is when it did work, try restoring the PC back to that date and see what happens.
    It seems to have fixed itself overnight, I didn't even turn the laptop off.
    "Magic". LOL. At least its corrected.
    It's not really "magic", audio drivers like most other are known to "crack" every now and than because of some program that messes around with settings and some other program may just restart a driver and go back to default settings.
    countmike, don't take my statement serious. But, it is a common response in the US when something mysteriously fixes itself.
    I know, so is here and Canada too but I just offered possible explanation, other than "somehow it fixed itself".
    Thanks for the explanation, I prefer the idea of magic, HP laptop = Harry Potter laptop?
    I will remember that so I don't start sulking if it happens again.
    Sweden
    Windows 8 Professional x64
    Had the same issue todayv when pluggin in to stereo from headphone jack, so i had to pop in my external usb soundcard
    Just flat sound, no bass at all
    I've realised it does it after it's been plugged into the TV via HDMI.
    Everytime I use the headphones after it sounds terrible.
    I can fix it by just disabling the sound device and then enabling it again. But, as you'd expect I don't want to have to keep doing this.
    Any suggestions on how to stop it happening in future.
I just bought a Dell Inspiron 17 laptop with Windows 8.1. When I first plug my headphones into the audio jack it works and it's initially silent. However, after I finish playing any sound from any app through the headphones, a static sound constantly comes through them. It doesn't sound like...
I bought the plantronics .Audio 335 studio headphones, but when I plugged them in, it screwed up my sound. My compute'rs sound is now playing through both the headphones AND the laptop speakers. After unplugging it and trying again a couple times, I gave up and decided to just use my old...
Hi. I recently bought a new pc and for the first few days the sound was working fine. This morning, some sound is not working, and some is working fine. Some youtube audio appears to be working and other youtube audio does not work at all. It seems like sound on certain frequency or band is working...
Hi, I have a HCL laptop with Windows 8 Pro x86 installed. Whenever I connect my headphones I don't get any sound from it. I have gone to my "Playback Devices" and selected "Show Disabled Devices" and the headphones are not listed there. What can I do to work around this problem ? I need my...
HP Pavilion dv6-6110us Entertainment Notebook PC laptop running windows 8 upgraded alright. Left the computer on overnight now the sound will not play through the computer speakers unless something is plugged into the headphone or microphone jack. But will play through external speakers... but not...
No sound with headphones? in Sound & Audio
Hey guys, I have the consumer preview Windows 8, No problems with sound initially until i plugged in my headphones. No sound at all, at first i thought the headphones where broken so i tried 3 other pairs of earphones and still nothing. Anyone have any ideas as to whats going wrong?
No sound thru headphones in Sound & Audio
On my home-built PC with dual-boot XP and Win8 RP, I can't get any sound thru headphones connected to the tower case's front headphone jack. I get sound through the speakers built into my display, which is connected to the mobo on the case rear panel. Sound comes thru headphones fine in XP. ...
