Mic and headphones only partialy work since Realtek HD Aud
BDani
So I had this fresh Windows install. Everything was normal, I plugged my earbuds into the cable and the cable into the rear green and pink I/Os... As always!
Now, I was able to hear everyone, and everyone were able to hear me, its just that when I listen to music, and talk to friends on Skype, or play games while on Skype, my friends can hear everything I do and its annoying. So I figured I need to install realtek HD audio drivers. Once I did, I was able to hear them but they weren't able to hear me. My mic stopped working and the weird part is that they were able to hear my Windows sounds. All the sound tests I've done, they were able to hear it, but not my voice.
I uninstalled the driver and from their it was a total disaster. I disabled and enabled drivers, updated them through Windows updates and all of the sudden the mic works but I can't hear anything, then after another restart and changes, I can hear everything but the mic doesn't work.
I'm completely lost, and sick of doing system restarts all the time.
Currently, my mic seems to work but I can't hear anything. Why? And what should I do?
EDIT: I just uninstalled Nvidia HD Audio drivers and installed only realtek. Only mic doesn't work, but speakers and headphones do work...
    Windows 8.1 Pro x64
    Intel Core i5 4460 @ 3.20GHz
    Gigabyte Technology Co., Ltd. H97-D3H-CF (SOCKET 0)
    8.00GB Dual-Channel DDR3 @ 799MHz
    1023MB NVIDIA GeForce GTX 560 Ti (Gigabyte)
Well, just which sound CODEC chip do you have ?
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Windows 8.1 Pro x64
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Windows 8.1 Pro x64
how do I check?
Computer manual and/or specs would be a good start, usually somewhere at the beginning.
I used Everest... It says:
Audio Adapter Intel(R) 9 Series Chipset Family High Definition Audio Controller - 8CA0 [8086-8CA0] [NoDB]
So Realtek drivers can't work, Realtek is manufacturer of sound and other chips and are not going to write drivers for somebody else. Which computer is that ?
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
Operating System
Windows 8.1 Pro 64-bit
Haswell 22nm Technology
RAM
8.00GB Dual-Channel DDR3 @ 799MHz (11-11-11-28)
Graphics
SyncMaster (1920x1080@59Hz)
Intel HD Graphics 4600 (Gigabyte)
Storage
465GB Western Digital WDC WD5000AAKS-00M9A0 (SATA)
Optical Drives
DTSOFT Virtual CdRom Device
HL-DT-ST DVD-RAM GH22NS30
Audio
Realtek High Definition Audio
    Windows 8.1 Pro x64
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Windows 8.1 Pro x64
Still having this issue, please help me.
    Windows 8.1 Pro x64
