Best Sound Card for Beats Studio
    Hi, I am considering to make a Editing PC to make Dub step on, I am definitely getting a pair of Beats Studio Headphones, I wondered what will be the best sound card(I am only using 1 pair of headphones)
    I have a recording studio (using Sonar X3). If I wanted the best audio for audio editing, recording, etc I would consider a USB connected "recording interface unit". Not any "PC Audio" (that includes SoundBlasters).
    Beats Audio headphones do not get good reviews on recording forums.
    Huh, integrated sound
    Windows 8.1 Update 1
    Quote Originally Posted by Xx3qmxX View Post
    Integrated sound cards are rubbish. If you want decent sound you need a dedicated sound card. Ausus are offering some good cards. There are also pro cards available but they are far too expensive and restricted in their use (no home cinema etc.) Creative cards are not bad as long as you don't mind possible driver problems (they are notorious for their bad driver quality). But no matter what you choose, don't go for the cheap card, if you do you can also stick to your motherboard's integrated sound chip. For top sound quality you will have to invest between 150 and 250 $ to get something decent, depending on your needs. Creative and Asus websites are a good place to start.
    The person who said he had a editing pc had intergraded sound.
    And? How does that in any way conflict with my statement that integrated sound chips are rubbish? Almost every modern pc/ laptop comes with integrated sound. This does not make it any better.
    Sorry to hear that, there are so many higher quality choices out there with much better sound quality.
    But I have a proper sound card
    In that case you have at least got a solid base. What card have you got?
    Lytle TX
    I would say to get better headphones then worry about your sound card... Say away from beats if your interested in making any kind of Music... Some proper Sennheiser or Audio-Technica headphones should sound a world of a difference.
Page 1 of 2 12 LastLast
Sound Card not working in Sound & Audio
EDIT: I fixed it by uninstalling the xonar dg drivers, shutting down, then removing the sound card. Why did I buy this thing anyways.. the onboard sound sounds just as good. -All Windows 8 updates installed -All drivers I could possibly think of to install, installed This all started when I...
Sound Card Recommendations in Sound & Audio
Hi, I am looking for a decent quality sound card for the rig that is detailed in my profile. I have a budget of around 60 I was wondering if anyone on here can recommend a good sound card or if anyone has any experiences with any? Thanks for your help.
Solved Sound Card Issues in Sound & Audio
Every 5 days or so, my sound card will have a bad day, and all noise coming through my headset will be distorted and static-like. Usually restarting my computer will fix it, but today it stopped working altogether. I check the computer, and it says that no headphones or audio are plugged in. I...
Sabrent SBT-SP6C sound card in Drivers & Hardware
By any chance anybody has this card and figured out how to get this card to work under Windows 8? There's no W8 driver and W7 driver doesn't work.
Virtual Sound Card? in Sound & Audio
I just bought new speakers and want more boom out of the sub so installed SRS audio sandbox. it tells me on startup however that there is no compatible sound card to use. I am running windows 8 on a laptop so I cannot install a sound card. is there any way I can emulate a sound card so I can use...
