Solved Best Sound Card for Beats Studio
Xx3qmxX
I don't really like stalkers
Hi, I am considering to make a Editing PC to make Dub step on, I am definitely getting a pair of Beats Studio Headphones, I wondered what will be the best sound card(I am only using 1 pair of headphones)
    Windows 8 (Will go to 10)
    HP Pavillion 15-n090sa
    AMD A8-4555M APU
    Hewlett Packard 216B
    8Gb (2x4Gb) DDR3 @ 1366Mhz
    AMD Radeon HD 7600G 768Mb @ 668Mhz
    Realtek High Definition Audio
    15" Smart Touch Display
    1366x768 pixels
    1TB 2.5" HDD
    HP Battery..
    HP Pavilion 15, 15" Silver Shell
    2 Noisy Fans
    GB Keyboard
    Dual Button Mouse
    1Mbps Down 100Kbps Up
    Windows FireWall
I have a recording studio (using Sonar X3). If I wanted the best audio for audio editing, recording, etc I would consider a USB connected "recording interface unit". Not any "PC Audio" (that includes SoundBlasters).
Beats Audio headphones do not get good reviews on recording forums.
Huh, integrated sound :roflmao:
    AMD A8-4555M APU
    1366x768 pixels
    1TB 2.5" HDD
    HP Battery..
    2 Noisy Fans
    GB Keyboard
    Dual Button Mouse
    Windows FireWall
Integrated sound cards are rubbish. If you want decent sound you need a dedicated sound card. Ausus are offering some good cards. There are also pro cards available but they are far too expensive and restricted in their use (no home cinema etc.) Creative cards are not bad as long as you don't mind possible driver problems (they are notorious for their bad driver quality). But no matter what you choose, don't go for the cheap card, if you do you can also stick to your motherboard's integrated sound chip. For top sound quality you will have to invest between 150 and 250 $ to get something decent, depending on your needs. Creative and Asus websites are a good place to start.
    Windows 8.1 Update 1
    self built
    AMD FX-8350
    Gigabyte GA-990FXA-UD7 Rev. 3
    16 GB
    Zotac GTX 770 Amp 2 GB
    GDATA Internet Security
The person who said he had a editing pc had intergraded sound.
    AMD A8-4555M APU
    1366x768 pixels
    1TB 2.5" HDD
    HP Battery..
    2 Noisy Fans
    GB Keyboard
    Dual Button Mouse
    Windows FireWall
And? How does that in any way conflict with my statement that integrated sound chips are rubbish? Almost every modern pc/ laptop comes with integrated sound. This does not make it any better.
    self built
    AMD FX-8350
    16 GB
Sorry to hear that, there are so many higher quality choices out there with much better sound quality.
    Windows 7
    Self-Built in July 2009
    23" Acer x233H
    Intel X25-M 80GB Gen 2 SSD
    Corsair 620HX modular
    Antec P182
    stock
    ABS M1 Mechanical
    Logitech G9 Laser Mouse
    15/2 cable modem
But I have a proper sound card
    AMD A8-4555M APU
    1366x768 pixels
    1TB 2.5" HDD
    HP Battery..
    2 Noisy Fans
    GB Keyboard
    Dual Button Mouse
    Windows FireWall
    self built
    AMD FX-8350
    16 GB
I would say to get better headphones then worry about your sound card... Say away from beats if your interested in making any kind of Music... Some proper Sennheiser or Audio-Technica headphones should sound a world of a difference.
    Asus K55A
    Intel Core i5 3rd Gen
    8 GB
    Intel HD 4000
    Audioquest Dragonfly 1.2 + Realtek "HD" Audio
    Built in + Sony 24" PS3 Display (3D)
    1366x768 (Built in) + 1920x1080 (3D display)
    750 GB 5400 RPM HDD
    RocketFish 90w Power Brick
    Logitec K400r
    Logitech M215
    1.5 Mbps down , 350 Kbps up (Rural)
    Microsoft Defender
    Custom
    Intel Haswell i5 4690
    Asus Z97-A
    2 x 8gb HyperX, by Kingston
    None yet
    Outboard USB DAC
    Samsung S24D360
I agree 100%. Stay away from those Beats if you are trying to edit music.
    Custom
    Asus Z97-A
    None yet
    Outboard USB DAC
    Samsung S24D360
Well I think this thread is useless anyway. Anybody dared to look at the OP's profile? The system in question is a Mac. What's more even though the OP was asked multiple times what his current sound card was he has not answered so far. So, how should anybody be able to help?
    self built
    AMD FX-8350
    16 GB
