W8.1 No sound coming from the front.
    Windows 8.1 - 64-Bit
    Hi.
    I have so many problems with windows 8.1 i have seriously no idea where to begin.
    First one i would like to have fixed is this damn sound, happened to me first time i installed windows 8.1 aswell, and i have no idea how i fixed it.
    The speakers are set to Quadraphonic, i have tried all of the settings, none of them work, i ONLY get sound from the LRear and the RRear bot NOT from the FRONT. Meaning that i cant even watch a movie because i hear NO voices, i only hear what is supposed to be behind the camera, i have uninstalled the driver and it automaticaly reinstalled, no success.
    Second thing i would like to add to this post is internet connection in windows 8.1 I have this EXACT problem on FOUR different computers, one desctop PC(The only im currently trying to fix) and 3 laptops.
    The problem is websites load about 50% of the time, 40% of the time they load extremely slow and 10% of the time they just work like they are supposed to.
    This is NOT a problem with my router or such, i have tried at several different places with high speed internet and its all the same.
    Thanks for your help.
    Central IL
    Linux Mint 17.2
    First off, it helps to know the brand of speakers you are using. Second would be which exact version of the Asus Rampage motherboard you have. The most common problem is that people plug their speakers in incorrectly.
    Quote Originally Posted by broe23 View Post
    Hi, im sorry if i sounded a bit rude, i was very frustrated yesterday with all these things going wrong.
    I only typed in Asus Ramage because that was all i could remember about its name, but i think it was Asus Rampage II or something like that.
    I fiddled with the sound a bit, i used both headset and Logitech Z-5500. I got the front speakers to work but the back ones doesnt work anymore.
    I guess this works for now since i can hear voices in movies now but it would be nice to have the correct setup.
Just set up new asus essentio series desktop with windows 8.1. After initial set up the monitor speakers are on but no the connected external speakers. I assume I need to make some change in the control panel. Is that true. I want sound to come through external speakers.
Recently i had this repair on my netbook screen which was needed to be opened... then after that when it returned and opened the system (i was still using windows 7 back then) all music played...it will play, but all i can hear is that sound that you can hear from a plane engine when taking off...
No sound from front panel in Sound & Audio
Yeah so my front panel is connected to my board but im still not getting any sound Usually in the good'ol versions i would disable front panel detection from the realtek driver utility but i dont have that on this computer
Hi, I'm so so sick to death of this. Microphone won't work at all. The plugin for the headphones works SOMETIMES. Right now it's not. It's a good system so I'm thinking it's the Creative drivers which are up to date. It's an Audigy card. Not sure what other info will be needed. ...
I was working on my computer editing music when suddenly all sound stopped. If I go into the sound mixer from the taskbar there is nothing listed under applications under speakers. If I plug headphones in sometimes Chrome shows up under applications, sometimes it doesn't. Right now headphones...
Front panel no left sound in Sound & Audio
Hello, I've got an Z77 Pro3 mobo (Asrock) and a Bitfenix Shinobi case. I've installed the HD-audio plug from the case to the motherboards hd-audio place correctly. My problem is that the case's front panel gives sounds only to my headsets right side but not to the left side. The microphone...
Sound isn't coming out in Sound & Audio
When I tried to play a video on Youtube I couldn't hear any sound coming out. I tried some things, but without any luck. Someone please help.
