Problem Installing Quicktime 7
    I need to install quicktime 7 for my airsight IP Cameras. Problem I am having is that the installation just keeps on trying to install it. I wait and wait, nothing happens. Then I try to uninstall, can't because it is still installing. I Turn off the computer, then tried to install quicktime 7 again and It says its still trying to install from the previous program. I can't close out the Windows installer box from the desktop... only when I turn the computer off. I do need to install quicktime to use the cameras in live view to see the video. Is there something wrong with Windows installer on my 8.1 or what?
    This is not a problem for this forum section. But, try installing Quicktime as Administrator. Right click on the Quicktime install icon and then left click Run as Administrator. See if that helps.
    BTW, I have iTunes and Quicktime installed and did not have any problems. So its not a Win 8.1 compatibility issue.
    United States
    Windows 8.1 Pro 64-bit
    Don't know if it will work in your particular situation but Quicktime Alternative works on my machine.
Why cant I use scroll/trackpad swipe to go back/forwards on timeline in QuickTime on Windows? I use two fingers to scroll and multitouch on other applications. I have tried to install both older and update to newer versions of QuickTime, but nothing works. I need this function when analyzing...
I bought the Windows 8.1 student edition to install on a new PC. I used Microsoft's media creation tool to get Windows onto a USB for the PC to boot from. I've tried selecting all the editions (N, Pro N, etc.) when doing the media creation tool, and I've selected the 64 bit, but each time I input...
Quicktime stopped working. Logged in as admin. Uninstalled then tried reinstall of 7.74.80.86 and 7.6 using 'run as admin'. No luck. Insufficient privileges to the directory--c:\program files (x86) Quicktime. When I look at the folder properties under security---'You must have read permission to...
Quicktime 7 ? in Software and Apps
Hi, I need to download Quicktime 7 and it says it works with XP, Vista and Windows 7. Could you tell me if it will work on Windows 8? Thank you.
For some reason quicktime files are choppy and jittery during playback in Windows 8. I have the latest Quicktime installed with no other codecs. I tried playback in the quicktime player as well as in adobe products (premiere, after effects, etc.). Here's a preview of what the playback looks...
Problem installing in Installation & Setup
Hi- I tried to install Windows 8 on to a new partition on my PC several times, It appears to install correctly but after it has installed and restarted, and gone through the registry setup files etc the screen just goes black and nothing happens. I've tried 'refreshing the PC' - this doesn't...
Quicktime in Software and Apps
Finally got Quicktime Pro up and running for streaming and stand alone, etc.. I was unaware that you now have to download it separately. Apparently it's no longer included in when downloading iTunes. Seems to work fine in Windows 8. 37683769
