sound gone after switching speakers to headphones!
    Hello, this is really strange. Whenever I unplug the speakers jack and plug in the headphones, the sound stops! I have to restart the application or run another one and then the sound is back. This is really silly and takes time especially when you need to restart some game. Why does it happen and how can I disable this stupid behavior? Thank you
    N.Y.
    Windows 10 Pro 64bit
    Which brand or type headphones ? What sound stops, speakers ? This a Laptop ? Check Sound Properties in control panel when you do this.
    It is a desktop computer core i7 on Gigabyte X58A-UD3R integrated audio and as I said the sound just stops. I can just unplug the headphones or speakers and plug them back but there is still no sound! For example while playing a youtube clip and I unplug and replug the jack, the video keeps playing, but without sound. Sound starts again when I jump to another time in the clip or refresh the page. Unfortunatelly in games I have to restart it. I guess it may be a driver problem of the integrated audio. It says high definition audio device in device manager, so maybe I need to get some official driver, but I am not sure they exists for Win8 and this board...
    Why do you think the brand of headphones would be of any use? They are some cheap genius, but as I said it happens both with speakers and headphones.
    Why are you unplugging the speakers, to plug in headphones? Don't you have the speakers connected to the rear GREEN speaker jack and have a headphone jack on the front of the case? That is the normal way of doing things. If the proper front panel connection is made to the motherboard (HD Audio Connector) then it should sense the headphones and automatically switch.
    Fireberd, because the cable would get into my mouse and I would have to make its way around a keyboard and such. It is just easier to unplug it from the motherboard and plug another cable. Anyway
    I FIXED IT by installing gigabyte audio drivers for Windows 7 even though I have 8... Now when I unplug the cable and plug another one it shows some dialog asking me if it is headphones, front speakers, rear and other choices and it works AFTER I click OK. I find this silly why does the sound stop when I do not have this Realtek audio manager installed and just use the default microsoft drivers so there is no way to click into non existing dialog? Strange...
    I had a Gigabyte motherboard and used the Win 7 RealTek drivers on Win 8 and they were compatible, too.
The title pretty much says it all. I realize there are other threads out there similar to this, but their solutions either didn't work for me, or the problem wasn't quite the same. My issue is as follows: When I plug my headphones into my laptop (hp dv7t 6c000 quad) audio plays through both the...
Dear all, I've been facing an issue with my sound lately (potentially linked to the win 8.1 update - as seems to be the case of a lot of people); I'm unable to get my sound to work, and I'm getting the following error message: "No speakers or headphones are plugged in". I've been trying out a...
Hi friends, I am using Windows 8. I am facing an issue with my sound all on a sudden. The volume icon on the task bar has a red cross on it. When I hover on that it says 'No speakers or headphones plugged in' (attachment-1). When I click on the icon I get a screen like attachment-2 which...
I bought the plantronics .Audio 335 studio headphones, but when I plugged them in, it screwed up my sound. My compute'rs sound is now playing through both the headphones AND the laptop speakers. After unplugging it and trying again a couple times, I gave up and decided to just use my old...
Hi! Sorry if this topic already exist, but i think it is little different. I had this problem, i went to BIOS and enabled sound, but, when i turned on computer there was sound, but it was show as headphones, and speakers aren't plugged in. Actually is opposite, headphones aren't plugged in, but...
I have 2 speakers plugged in on m motherboards audio jacks, and my G110 keyboard has sound card of it's own built in. I was wondering if there was any way to set it up the way I want it, or something similar to it. The keyboard has a headphone mute button of its own. So I was thinking that I...
Hey back In windows 7, When I plugged in a pair of headphones the sound automatically changed to the what it was last time I plugged them in. And when I unplugged them, the sound switched back to speakers... In windows 8 (not pro version) when I plug in headphones, the sound doesn't go...
