Audio Stutter??
    Win 8 Consumer Preview
    Audio Stutter??
    I have a problem with the Windows 8 preview, my audio driver and everything works fine, or so it seems. However when playing music or a game or a movie randomely sometimes often sometimes not the audio will have a slight hiccup or stutter, it does not do this right after a restart but it gets worse the longer the pc is on. If i restart the problem goes away for a bit. This does not happen in win7 for me. Whats the issue? My mobo uses realtec audio
    Hi,
    Realtek <<< Install HD Audio Codec driver from the right side.
    Realtek HD Audio 2.67 audio driver download from Guru3D.com <<< Mirror link to same driver
    Very important to update all other drivers too, from manufacturers' sites, especially wireless network and then wired.
    If you have 3rd party security installed of any type, uninstall to test.
    hi, i already tried installing that as well, i currently have the hd audio manager in my taskbar too. I still have audio stutter
    And has the rest of my post been fully considered with all options exhausted?
    yes, all my other drivers are up to date and i dont use any security besides the built in one to windows
    Cool - in that case I wouldn't mind looking over the system to see what I can find. You can run the tool found in the top most thread in the Crash and Debugging subforum, then attach the zip it makes to here, in a new post.
    Here ya go! Thanks btw
    Audio Stutter?? Attached Files
    Your machine suffered from a bsod today, caused by your very old Marvell storage driver:
    3: kd> lmvm mv61xx
    fffff880`00c19000 fffff880`00c5f000   mv61xx   T (no symbols)
        Loaded symbol image file: mv61xx.sys
        Image path: \SystemRoot\System32\drivers\mv61xx.sys
        Image name: mv61xx.sys
        Timestamp:        Thu Mar 19 23:48:21 2009 (49C31205)
        CheckSum:         000320F6
        ImageSize:        00046000
        Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
    Update him from here: Marvell - Support - Driver Downloads
    Visit ASUS site for your motherboard to update this ancient notorious driver:
    ASACPI   ASACPI.sys   Sun Mar 27 22:30:36 2005
    It will be in the Downloads | Utilties section. It's name is ATK0110.
    Logitech game (pad, controller?) driver could use an update:
    LGBusEnum LGBusEnum.sys Mon Nov 23 20:36:48 2009
    LGVirHid LGVirHid.sys Mon Nov 23 20:36:48 2009
    AMD Video card driver could use an update:
    atikmdag atikmdag.sys Wed Nov 09 21:52:46 2011
    AMD Catalyst 12.3 WHQL 32-bit download from Guru3D.com <<< (Or, you can install Windows 8 Consumer Preview driver instead.)
    And finally, back to square one. Your Realtek HD Audio driver is ancient:
    RTKVHD64 RTKVHD64.sys Fri May 22 14:04:20 2009 (4A16E924)
    Update from the link(s) in my first post.
    You're welcome and enjoy.
    Those preview drivers dont work at all with the 4800 series and thus i had to install the only version that does work for my card, the logitech drivers came with the newest software they provided, and i literally just reinstalled my audio using that link you provided. I got the BSOD when it tried install the marvell drivers directly from the asus site for more mobo. I will try to install the link you provided but other then that there is nothing really i can update.
    Sure, the preview driver works for any and all HD cards.
    Logitech's site is good to download from.
    As far as reinstalling audio, you'll have better success by uninstalling the driver in the device manager while also checking the box to delete the driver. Then run the installer after. Then reboot.
    Don't download the ASUS storage driver. Use the link provided.
Page 1 of 2 12 LastLast
Audio Stutter??
***SOLVED*** Problem was an older PCI SATA I controller with a VIA chipset (NOT THE GTX 670). Replacing it with a newer PCIex1 SATA III card with a ASMedia chipset has eliminated the occasional stutter...
Sound and Video stutter. in General Support
Hi, I'm experiencing fairly regular stutters while playing either video or audio files when these are saved on my HDD. I have both a SSD and a HDD. I keep all my video and audio files on my HDD because my SSD obviously has a lot less space on it. It seems these stutters occur because the HDD...
I have an older setup (1366 i7 930) that has worked well for years with XP, Win 7, Win 8 and now running Win 8.1. About 4 months ago I started getting every kind of problem known to man: BSODs, audio skips and stutter, video hangs and blank screens (with mouse cursor still working), slow...
Audio Stutter in Sound & Audio
Hello, I've seen many threads around these forums regarding this issue but I didn't come across a "fix". My situation is the following: Every now and then, the audio of the PC stutters, its like it skips kinda when you're listening to music from a bad CD. I have the latest drivers from my...
This is driving me nuts! Bought this Pavilion p6-2317c desktop a couple months ago. It has Win 8 x64, 8gb ram, and integrated IDT audio. It worked great out of box for a while, then I started noticing a slight break or stutter in music, whether online or on my hard drive. I tried installing fresh...
I upgraded from Win7 to Win8 (both running the MS Media Center) and it's created a problem with music playback . It used to work fine, but now I get random stutters. Sometimes it goes 10 or 15 minutes without any problem, but often it's more frequent than that - and it's very, very annoying. The...
Freeze/lag/stutter.. maybe twice a week in Performance & Maintenance
I have Windows 7 on my 500 GB HDD which never had any issues Recently I installed Windows 8 on a new Crucial M4 SSD and I noticed issues with Windows 8 which would occur maybe twice a week until I restarted. I notice it once a website starts taking a while to load, I attempt Ctrl + Alt + Delete...
