The other day I turned on my computer and my audio would not play. A small icon that resembles when the volume is muted is permanently displayed. When clicked, a window titled: "Playing Audio" opens and tries to troubleshoot the issue. It comes up with the following:
Problem found:
One or more audio services isn't running. Not fixed
Both the Windows Audio and the Windows Audio End Point Builder services must be running for audio to work correctly. At least one of these services isn't running.
Potential issues that were checked:
Check audio device. Issue not present
My computer is a Sony Vaio, model number SVS1512DCXB.
All important original drivers and applications can be found here.
In case you can't retrieve any information on my computer, important information is as follows:
My question to this forum is where to go from here? I've already downloaded both the Realtek, but when I ran the program, it threw an Error message saying "Install Realtek Audio Driver Failure! Error -0001"
I'm not sure how to fix this problem, and am looking for advice on what to try next.
Problem found:
- 64-bit Operating System
- 12 GB RAM
- Windows 8.1
- Intel(R) Display Audio
- Realtek High Definition Audio
- Windows
