Solved Dual audio issue Windows Media player Shark007 Codecs
aka40
Hello all,
I just installed the Shark007 Codecs and reboot the PC. Because, I need to play.MKV video files. I didn't change that plugin settings. Now when I play the AVI video files which has dual audio (two languages), now Windows Media player automatically playing both audio sounds.
When I search on the internet, I found that setting Haali as the AVI splitter in the AVI tab will fix it. Unfortunately, in my situation, it didn't work. After I choose Haali splitter, it shows "Windows media player encountered a problem while playing the file" error.
So how do I disable 2nd audio auto playback?
Thanks!
    Windows 8.1 pro
    Intel
    Intel
    2GB
    Intel
    Intel
    ViewSonic 19 inch LCD
    720P
    HP
    HP
    1Mbps
    Chrome, FF
    Bitdefender internet security 2014
Fixed the issue by using LAV's splitter.
    Windows 8.1 pro
    Intel
    Intel
    2GB
    Intel
    Intel
    720P
    HP
    HP
    1Mbps
    Chrome, FF
