Sound playing through both laptop speakers and headphones
    I bought the plantronics .Audio 335 studio headphones, but when I plugged them in, it screwed up my sound. My compute'rs sound is now playing through both the headphones AND the laptop speakers. After unplugging it and trying again a couple times, I gave up and decided to just use my old headphones.
    Except for the sound still played through both the headphones and laptop speakers.
    Distraught, I restarted my computer. When that didn't work, I restored my system to a point I made yesterday. Still no luck. I've been scrounging google for a few hours now, and nothing is helping. Any ideas? I REFUSE to refresh my system and reinstall all of my programs again.
    This is urgent. I'm a freelance musician and require headphones for my work.
    United States
    Windows 8.1 Pro 64-bit
    Have you tried with and without the microphone adapter? In your sound device manager see if there is a setting you can change when the headphones are plugged in.
    Something in settings like this:
    Quote Originally Posted by popeye View Post
    Yeah, I've tried that.
    Like I said, it still plays through both sources when I use my other headphones.
    United States
    Quote Originally Posted by larynachos View Post
    Sorry, I missed the part about it happening with different headphones. It could be a jack problem. Have you tried spraying it with a can of compressed air? Is it a desktop? The jacks on those are much easier to replace than on a laptop.
    It's an hp pavillion sleekbook 15 (laptop). I tried compressed air, but nothing changed.
    United States
    Sounding more and more like the jack is bad. About the only other thing you could try is delete the audio devices in Device Manager and reboot, see what happens.
I just bought a Dell Inspiron 17 laptop with Windows 8.1. When I first plug my headphones into the audio jack it works and it's initially silent. However, after I finish playing any sound from any app through the headphones, a static sound constantly comes through them. It doesn't sound like...
I have an HP laptop running 8.1. I did update my computer or I restarted after an automatic update but no sound comes from speakers or head phone jacks. I have checked my drivers and they are working. My sound is not on mute. Any suggestions?
The title pretty much says it all. I realize there are other threads out there similar to this, but their solutions either didn't work for me, or the problem wasn't quite the same. My issue is as follows: When I plug my headphones into my laptop (hp dv7t 6c000 quad) audio plays through both the...
Used my computer after work to listen to music with headphones in and it sounds rubbish, bearable but rubbish. I have Sennheiser headphones that usually sound fantastic, they still do sound fantastic on my phone listening to the same song on Spotify. Anyway, tried Spotify and YouTube and the...
Hello, this is really strange. Whenever I unplug the speakers jack and plug in the headphones, the sound stops! I have to restart the application or run another one and then the sound is back. This is really silly and takes time especially when you need to restart some game. Why does it happen and...
I dont get it, when i connect my headphones they work OK, but i can also hear trow my laptops speakers and they are not disabling themselves like they use to. its a huge problem and my roommate is going to kill me, i will appreciate your help ASAP
Hi, I have a HCL laptop with Windows 8 Pro x86 installed. Whenever I connect my headphones I don't get any sound from it. I have gone to my "Playback Devices" and selected "Show Disabled Devices" and the headphones are not listed there. What can I do to work around this problem ? I need my...
