Solved Changed my motherboard sound device not found; OS problem
Andre
My control panel sounds option says that I don't have audio devices installed so
I tried troubleshooting it but it says :
but my device manager says this:
My computer also says I need to activate my windows. What is wrong with my PC?
I cant un-attach these two photos sorry
    Windows 8.1 64-bit
    Intel Core i3-3240
    ECS H61H2-M17
    4 gb
First it says you have to activate windows because you changed the motherboard and it sees it as a new system. If thr on-line activation doesn't work you will need to call the phone activation.
Now for the sound. Start by deleting all the sound devices in device manager and reboot. What motherboard make/model? Never mind, see it in your specs.
EDIT: Your new board has a VIA audio chip from what I see, Not Nvidia. Do you have a separate sound card?
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
I did everything you said and now it works the way I want so thank you very much for that.
Now for the windows dilemma. How do I do "on-line activation". All I can see is phone activation. It's 1 am here and I'm pretty sure they don't answer calls this late. I'm from the Philippines and the according to their list of phone numbers there's only 1 Microsoft Centre for our country and I live pretty far away from it, can they still re-activate my account? Thanks in advance
    Windows 8.1 64-bit
    Intel Core i3-3240
    ECS H61H2-M17
    4 gb
Glad you got the sound going. You have 30 days to activate so plenty of time, The phone activation should work fine. It is automated and all you so is provide the key, then it rattles off a bunch of numbers for you to enter and activate. If that fails then you can get a person on the phone who will make it work.
Edit: Just realized should ask if you have retail or OEM 8.1. If OEM you may run into problems activating. Did you get the key out of the BIOS before changing boards?
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
Hmm. I dont know. I bought the motherboard at a Pc-express shop and I let their technicians put it back together. What key should have I taken from them?
    Windows 8.1 64-bit
    Intel Core i3-3240
    ECS H61H2-M17
    4 gb
When you originally bought the computer did you buy Windows 8 or did it come pre-installed? Do you have a disc?
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
I have the disc and I have the product key but when I input it it says key in use :think:
    Windows 8.1 64-bit
    Intel Core i3-3240
    ECS H61H2-M17
    4 gb
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
Tried, didn't work. Thanks anyway. I'll just call them later in the decent hours. Thanks for you time :thumb:
    Windows 8.1 64-bit
    Intel Core i3-3240
    ECS H61H2-M17
    4 gb
Yea, short of a complete wipe and re-install, which it sounds like you don't want to do, a phone call is about all you have left.
Glad I could kind of help. :)
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
