surround sound with 2 sets of speakers, no bass from rear
    So as the title says, I have set up a surround sound system using 2 sets of speakers. The first set is set up as the front speakers in the realtek audio manager, and the second set is set up as rear speakers. I have it set up as 7.1 with no sides, subwoofer, or center speakers. Front, left, and right is checked, as well as surround sound. The sub is on my front speakers, and works fine. The rear speakers however get absolutely no bass, only treble, and sound super tinny and terrible. The speakers are fine, and work and sound great if there set as front speakers. What's the problem? I originally had another subwoofer/speaker combo hooked up as the rear, but the subwoofer didn't vibrate at all. I thought maybe I should just hook up some normal speakers with built in subs. Same thing though, they just sound terrible. I also have dolby home theater on, and if I shut it off the rear speakers don't even work when playing music. They work if I click the speaker icon in realtek.
    In many cases if you don't have an actual 5.1 or 7.1 system you can't "assemble" a surround system, or a system that works properly. In a surround system, there are three connections to the PC's audio and they go to the main unit (bass speaker) that has amplifiers and sound distribution.
    Trying to duplicate that with separate speaker systems can result in problems such as you are encountering.
    Okay, thank you. I am trying to get a nice speaker system for my computer, and am still learning. I see when browsing through speaker systems, there is a section containing av receivers. What exactly are these, and do I need one for a computer? Or are they just for theater setups?
    Also, I saw this video:
    https://www.youtube.com/watch?v=enn_YC9gryU
    And was a little confused how he did it. Both of the subwoofers are plugged into a y adapter, what does the subwoofer power? Does it run the subwoofer and the centerspeakers? So then the sides fronts and rears all have there own cable going into the computer?
    See my speaker right now has one wire coming from it. And that one runs the sub and the speakers.
    You actually have two 2.1 sets of speakers, right ? If a sub-woofer is not connected to appropriate connector on the audio card and does not have it's own amplifier, then you can't control it from software on the computer and you are at the mercy of it's own electronics.
No sound from speakers in Sound & Audio
Hi. Just got my Acer Aspire E5 572g back from repair at Acer Repair Center. They switched out my prosessor, but now i got no sound. The computer came back with a clean install og win 8.1. Added a screenshot showing drivers and that sound is "playing"...
Latest version of W8 This will take a while A few months ago W8 quit producing sound through my speakers - overnight. I've tried a number of things I'll list here. Volume Control - red 'x' in bottom right corner. AMD HDMI OUTPUT and HEADPHONES are checked. Troubleshooting Speakers/headphones...
rear speakers not working in Sound & Audio
all plugged in new computer drivers up to date set to quadraphonic they were working yesterday but they appear to have stopped on their own. the test speaker option worked at first but now they dont when i click the speaker icon to test on the sound playback options tab the level indicator...
Streaming to surround sound in Sound & Audio
Hi guys, I want to stream my music and videos from my laptop to my smart tv via Wi-Fi so I can listen through my surround sound system. I cannot seem to do it through the music and video apps in win 8.1 Anyone know how to set the apps to stream to DLNA devices? Thanks
I just got a whole Kenwood VR-209 Surround System with the 15" Woofers, Center Speaker and Rear Sperakers, the 200-Disk CD Changer, Dual Cassette deck and everything that came with it, for a very good low price. So, I plugged my HDTV into the "Video 2" Dolby Digital/PCM using an RCA Coax Cable -...
I have tried for some time now to get my surround sound to work on my Packard Bell Ixtreme X8540 since upgrading to Windows 8 via Microsoft's upgrade tool. When I had Vista installed, there was an icon on the bottom task bar which would take me to a control centre for the audio which gave the...
