No sound coming from external speakers
    windows 8.1
    Just set up new asus essentio series desktop with windows 8.1. After initial set up the monitor speakers are on but no the connected external speakers. I assume I need to make some change in the control panel. Is that true. I want sound to come through external speakers.
    Sounds like you may have a monitor with an HDMI connection. If this is the case, Windows automatically defaults the default audio playback device to the HDMI, if an HDMI cable is connected to the PC. If you want the PC sound you must manually change the default audio playback device to "Speakers" (PC sound). And you will likely have to do this each time you boot up. I was looking at a new monitor at either Sam's Club or Costco and decided against it as it was an HDMI connected monitor.
    The Sound/Playback panel can be accessed from start/Control Panel/Hardware and Sound
    windows 8.1
    Followed your advice and got it solved thanks.
Windows 8.1 Genuius SW-G2.1 1250 external speakers ASUS K56CB laptop When tested on other devices, the sound system blows the roof off. On my laptop, it doesn't (max level on computer controls, media player and speakers knob is lower). I'm pretty sure it's not the soundboard, but I've...
I have an HP laptop running 8.1. I did update my computer or I restarted after an automatic update but no sound comes from speakers or head phone jacks. I have checked my drivers and they are working. My sound is not on mute. Any suggestions?
Recently i had this repair on my netbook screen which was needed to be opened... then after that when it returned and opened the system (i was still using windows 7 back then) all music played...it will play, but all i can hear is that sound that you can hear from a plane engine when taking off...
No sound from speakers in Sound & Audio
Latest version of W8 This will take a while A few months ago W8 quit producing sound through my speakers - overnight. I've tried a number of things I'll list here. Volume Control - red 'x' in bottom right corner. AMD HDMI OUTPUT and HEADPHONES are checked. Troubleshooting Speakers/headphones...
Hello, I just bought a new pc and received it today, and i plugged my headset in to check if i hear audio from both speakers and headset but its not working. When i plug my headset in i only hear audio from my headset and not the speakers. Ive been googling and found something about it but with...
HP ENVY 20-d094 TouchSmart Desktop How can I use 'external speakers' (using the external speaker jack on the back of my touchscreen) ... AND NOT have it over-ride the BEATS audio.? Once plugged in , the external speaker are heard BUT the BEATS AUDIO is muted. ! (OFF) Is there a way to...
