Audio suddenly too low
    I'm listening to an online training series of audio and video lessons. The sound suddenly has become so low that I can't hear! All the settings indicate the volume is maxed out. Speakers pass a test and otherwise work for things like itunes, just nothing I'm trying to access from the internet. Tried some Youtube videos just to test, and they are too quiet to hear as well.
    Canada
    Do you have volume controls on the speakers also if they are exterior speakers?
    United States
    Windows 8.1 Pro 64-bit
    Would also help to know some of your system specs like make/model of computer and make of audio controller/card.
Hey all, I've been using a Windows 8.1 HP Envy laptop for quite some time with no problems. It used to have very strong headphone output, and I could hear it just fine even at 2-3% volume. However, a few days ago I made the mistake of going into the preinstalled Beats Audio manager and...
So suddenly when the my laptop sleeps or turns the screen off, the audio device gets taken over by some hidden application or the optional update was just faulty. I've been experiencing this for two days now. Check the picture for more information 45223
I have a dual boot Win 7, Win 8 setup. Suddenly the audio has stopped working on Win 8. (Works fine on Win 7) I checked for driver updates, even "installed" an old driver which didn't actually install. The volume control shows its trying to work, puff of green comes and goes at the bottom of the...
