Realtek Enhancement Function Missing
    8.1 64bit
    Hello guys,
    My OS is 8.1 64bit
    Here's a problem I've encountered during the usage. (Intermediate mode/ Enhancement function missing)
    I've tried to find everything related to Realtek and my audio programs in my PC but I still couldn't figure it out.
    Went to Sound Manager etc, nothing's available for the enhancement.
    Or is it meant to be like this?
    United States
    Windows 8.1 Pro 64-bit
    Welcome to the forum Devin.
    I believe it is that way when Dolby is installed. I have Dolby and the same thing in the enhancement tab. All the enhancements are done through the Dolby tab.
    8.1 64bit
    Thank you, can't really tell if this case is really solved haha..
    so Dolby have a few setting like, Open, Rich, Focus.
    Can't tell if there really any big difference though..
    I was looking for an echo filter for my piano system.. my old Win 7 have this setting in the enhancement tab..
    United States
    You could uninstall Dolby and hopefully get the enhancement back. I'd back it (Dolby) up first unless it is on a disc or in a recovery file.
I am fairly sure I had this manager when I started with windows 8 . I have also done a clean reinstall after hard drive crash. it shows the in and out sockets on the back of the board(gegabyte GA-970A-DP3) AND ALOWS ME TO RE ASIGN THEM.. Can any one tel me how to get it back. very greatfull for...
48543 Does anyone knows how to solved this? I couldn't even change any of this settings here in this tab. Please Help
Hi I need help, can't find a solution and this is slowly driving me crazy... I installed the realtek drivers and they appear as installed in the control panel but it does not show up at the start up of windows, I have tried installing the latest drivers from realtek official page and the lates...
Performance Enhancement in Performance & Maintenance
Hello Everyone. I was looking around for a tips thread, but decided on this... Anyway, a nice feature to eliminate that flip on the start screen and more... Win + X > System > Advanced System Settings > Advanced (Tab) > Performance Group > Settings... >
Okay so I'm having dual boot in my pc. Windows xp home 32bit and 8 pro 32bit. I've used my Realtek/A-Link (stick says a-link but software is realtek) 8192CU wi-fi stick for like 3 years in my xp. This weekend I installed 8 pro and I can't access internet 'cause I don't have working drivers. I heard...
I have a PC built from an Asus P5B-WiFi Delux motherboard running Windows 8 Pro with Classic Shell which has an Realtek HD audio on board sound device. I also have a Creative X-Fi Gamer sound card installed. All of these were installed and working correctly. One time I unplugged my speakers...
