Remove SmartAudio link from Control Panel
    Win 8.1 Update 1, 64 Bit
    Hello, I need help removing the SmartAudio application from my Control Panel. Every time I click on it, it says "failed to initialize" - I no longer have it nor do I need it. I would just like to get rid of it from Control Panel, it's not slowing my system down or anything, it's the OCD in me that is killing me seeing a non working function there! Thank you
    I was able to fix it by installing the drivers and then manually uninstalling - if mod can delete this thread, that'd be great. thanks!
Control Panel in Software and Apps
Why is it that the last time I went to the control panel to uninstall a program it was no longer listed, And a lot of my programs weren't listed. Why is this ? it makes it impossible to uninstall most of my programs that I no longer want. I hate Windows 8.
How to Add or Remove Control Panel from Navigation Pane in Windows 8 and 8.1 This tutorial will show you how to add or remove Control Panel from the navigation pane of File Explorer for all users in Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1. This includes Control Panel for when...
How to Add or Remove Control Panel in This PC in Windows 8 and 8.1 This tutorial will show you how to add or remove the Control Panel folder in Computer (Windows 8) or This PC (Windows 8.1) in File Explorer for all users in Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1. You must be...
There is a weird thing in my control panel called Akami Netsession interface control panel, how can I remove it? It says Application not found when I click it. Screenshots: Screenshot by Lightshot Screenshot by Lightshot
How to Add or Remove "Task Scheduler" from Control Panel in Windows The Task Scheduler enables you to automatically perform routine tasks on a chosen computer. With this service, you can schedule any program to run at a convenient time for you or when a specific event occurs. The Task Scheduler...
Solved Control panel won't come up in General Support
Suddenly, when I try to access the control panel, all that happens is the control panel icon shows on the task bar but I can not open it. Nothing happens when I click on it. I've rebooted several times with no change.
Control Panel in General Support
I'm reading this book and it shows me what the control panel looks like in Windows 8 but I sure can't get to it. My control panel looks just like the one in Windows 7?
