Sound "bzzz" problem (not hardware)
    Hi,
    I have Windows 8.1 on my new (april 2014) laptop.
    After few weeks I noted some audio problems. When a video is on, the sound sometimes turns into a metallic "bzzz" sound (approx. half a second). It occurs whenever I open another tag in my browser, or when there is some Internet connection problem.
    I am almost sure it is a software problem. Here's why.
    I got rid of the "bzzzz" sound a first time after removing 3 trojans. After that, the sound was clean and perfect for a few weeks. Then it appeared again. I got rid of the problem a second time when I restored the previous Windows configuration (due to different problems). But after a couple of weeks the "bzzzz" appeared again. I got rid of it again when I reinstalled my antivirus software. But now it is here again. Not surprisingly, it got worse after the last periodical Windows update.
    Any suggestions? I would prefer to avoid to restore the previous configuration again.
    Thanks for any help.
    Windows 8.0 x64
    Try turning off the AV. It's been known to interfere.
    Quote Originally Posted by MilesAhead View Post
    It makes sense. But then? Who dares to use a computer without an AV? Moreover, mine cannot be turned "off".
    EDIT: my mistake, my AV can be turned off. Nonetheless, the "bzzz" is still there.
    Windows 8.0 x64
    There's more strategies to system protection/disaster recovery than just running with a prophylactic. Varying with the machine and the AV software the prevention can be more onerous than the disease.
    The "fixes" you list seem so varied all I can suggest is delete the audio device in Safe Mode an reboot to normal mode. Often when Windows reinstalls a device it does it right for some reason. This is a standard support trick that seems to work at least half the time.
    Any suggestion about that?
    Windows 8.1, Toshiba Satellite L50, Avast Internet Security.
    Windows 8.0 x64
    I rarely use AV except for scans. So I have no idea if this or that AV is better than another. This site is well respected for freeware lists:
    The Best Free Security Software for PC
    I just updated Windows 8.1. No "bzzz" sound. Will it last?
    8.1 made some changes to sound. Not sure what it changed, from Win 8, but I've seen several posts of people with sound problems after 8.1 and having to reinstall the sound drivers, or get 8.1 sound drivers. I even had that on my Roland Octa-Capture recording interface unit I use in my recording studio- Roland has to issue an 8.1 driver update.
    There again, as disturbing as ever. And no updates of anything since last post. Frustrating.
Hello, I am trying to install a driver for the Epson perfection 1200U on my grandpa's new windows 8 PC. Problem is that the scanner is too old and epson doesnt provide a driver for this scanner for windows 8. But I found a how to guide on this and the instructions are great, and it seems to work...
Hi all, My Win8.1 box keeps crashing in device manager upon any "refresh." For example, scanning for hardware changes, installing/uninstalling something, or updating anything. I've gone through and updated any drivers that I saw were old, but no joy. Any assistance would be appreciated!...
May I know what is happening on the pc ? Btw it webcam is not functioning from yesterday. It asked me to connect to a camera.
I have just installed Windows 8 Pro onto an existing Windows 7 Pro drive allowing dual boot. The problem is whenever Windows 8 is running I hear a sound every now and then. The sound is the "close program" default sound "ring07.wav. Why is this happening and how can I stop it? Thanks.
Hello all, I'm new here, so please bare with me. I'm assuming this is the appropriate section of the forum to post this question, so here it goes.... I've just had Windows 8 Home installed over the past months, and have now come across a strange problem, which seems not uncommon from other...
I cant see that option anymore when right-clicking a video -on both IE and chrome and going to setings !
So for some reason the BIOS suddenly decided all my SATA ports should be hot swappable I suppose. My C drive where my Windows install resides suddenly shows up under the "Safely remove hardware and Eject Media" thingy. Normally this wouldn't bother me, but now it's showing up as "oCsria roFcr e 3SS...
