Noise/Buzzing Heard in Headphones when Sound Unmuted
    Hi everyone,
    I have an interesting problem: On my laptop (Lenovo Y510p) I can hear a buzzing/whistling/noise sound while my headphones are plugged in. The problem goes away when I mute my sound, but this buzzing can be heard while booting as well.
    This led me to believe that my problem is simply a hardware issue, but I have a dual-boot setup with Ubuntu Linux on another partition where the sound works perfectly (i.e. no buzzing/whistling sound), which is interesting because it is using the exact same hardware.
    I've tried: Reinstalling the audio driver and using different headphones. Neither gets rid of the problem.
    Any help would be greatly appreciated! I'd be happy to provide more information.
    Do you have the correct sound driver installed? If you only have the "High Definition Audio Codec" installed, that is only the generic Windows installed sound driver and not the correct one. Although the driver is not an issue when booting.
    I reinstalled the driver from the manufacturer's website, but I still have the problem.
    Is the problem only with headphones? Do you get that on the built in Laptop speakers?
    Ubuntu uses a different driver(s) so it may still be there just not heard in Linux.
    Do you have any other external devices connected to the PC? Does this do it when on Battery only and the AC adapter not plugged in?
    (I have a Lenovo Ideapad Z560).
    As far as I can tell, I can't hear the buzzing through my speakers.
    The only other devices plugged in are my mouse and AC adapter. The problem persists when unplugging either of them.
    Thanks for the help!
    Can you try the headset on another device, such as an MP3 player.
    No noticeable buzzing on my MP3 player, or my tablet (also Windows 8.1)
    Do you hear the noise when only the BIOS is active?
    I hear it as soon as I boot up my computer, and it continues into Windows 8. If I boot into Ubuntu instead, it cuts out instead.
    So, you hear it when you first boot, but once Linux boots you do not hear it, but if you continue with the boot into Windows you still hear it. That suggests its an internal hardware caused problem, but what is Linux doing to suppress it???
Page 1 of 2 12 LastLast
Whenever i plug in my headphones, i hear a buzzing noise. its not the headphones problem, i tested them on other devices and there was no problem. I even changed speakers but i still have the prob, Please Help, ty. :(
so yesterday i got a random blackscreen and my headset came with a buzzing noise,while i was watching youtube. there were no bumpfile nor anywhere in event viewer were it said something had crashed. ive took the card out and made sure that everything was plugged well in. today it happend again...
When i use my headphones the work just fine for a while but then a crackling, popping noise begins. It happens whether i am listening to audio or not and it has happened with 2 pairs of headphones and a set of speakers that plug into the headphone jack in front of my computer.i have no idea if...
I have an ASUS LED monitor and an MSI motherboard. When the computer goes into hibernate the blue LED indicator on the face of the monitor blinks. When it starts blinking there is a slight buzzing noise that is emitted. Since my computer is in my bedroom I was hoping to be able to change this so at...
Irritating buzzing noise in Drivers & Hardware
Seem to be plagued with problems at the moment. Have just fixed one and now the Sandy Bridge is making a fairly loud buzzing noise a bit like a doorbell being pushed. It is fairly intermittent and the sound lasts for a few seconds or for a minute or so. It doesn't seem to be related to anything I...
I have the asus s400ca it has the microphone and headphone in the same jack. My headphones are fine in any other laptop but when I plug them into my new asus I hear very loud static even when playing music. It came with via hd audio and I can specify any other information if necessary, please...
buzzing sound and some lag in Performance & Maintenance
I need help ,some times I get this low buzzing sound in windows 8 while playing audio/video files and while gaming , It only happens for a couple of seconds , 2-4 seconds and then everything goes back to normal . this happens a lot of times . I'm using windows 8 pro 64 bit running the os...
