HP laptop No sound problem
    win 8.1 pro
    hey all
    i have a hp pavilion dv6-6150us ,,i was on youtube and suddenly the sound stopped working ,,no sound coming out from the laptop speakers ,, my on-board sound card is IDT ,,i downloaded the correct driver fro hp site ,,but it wont install ,, showing an error that the hardware detected is not supported by IDT software,, the sound only works when i connect my laptop to a tv using a hdmi cable ,, there is an "X" mark on my sound icon ,,i tired everything from uninstall ,remove ,re-install the audio drive ,, i think the problem is that its only detecte the graphic card hdmi as a playback audio device ,,and the onboard sound card is somehow disabled ,,i cant find the enable option on my bios setup !!
    i have some screen shots to help understanding my problem ..
    excuse my english !!
    Doublecheck the BIOS for the sound option. It may be listed as "legacy" audio controller, integrated audio, etc. If there is a BIOS reset option, you could also try that as generally the audio is enabled in the default settings.
    Also, reinstall the Intel motherboard chipset drivers and then see if you can install the IDT. The chipset drivers define (identify) all the devices on the motherboard.
    win 8.1 pro
    Nope that option is not in my BIOS setup i checked like a 100 times ... the bios setup is really stupid u cant change anything ,, here's a pic of the only settings in the bios
    tried to re-install the Intel motherboard chipset driver ,, still same problem !!
    still cant install the IDT audio driver
    Its got to either be a BIOS problem or a hardware problem. If the sound chip is being detected by Windows, the generic, basic function "High Definition Audio Codec" sound driver will be installed by Windows. Since this is not happening, either there is a hardware problem with the sound chip on the motherboard or somehow the BIOS has it disabled.
    Is there any option to reset the BIOS? Laptops can be a problem getting to the CMOS (BIOS) backup battery, but removing the battery (with the PC powered off) for AT LEAST 10 minutes will reset the BIOS.
    I missed the High Definition Audio Codec in the Device Manager. But, that appears to be for the HDMI audio, which means the correct video drivers have not been installed for that, either.
    win 8.1 pro
    i have easy access to the CMOS (BIOS) backup battery ,, there is a lock on the back of the laptop when u slide it opens a plastic cover to get access to the battery ,ram , hard disk, and the wifi chip ,, but if i removed it as u say for 10 mins will it do any harm to my laptop ,would i lose any data ??
    here's something i forgot to mention ,,i said i was on youtube when the sound got disabled ,the sec that happened i lifted my laptop and i found out that the table which the laptop was on ,was full of water ,, i turned it off and faced it to a fan ,,and i saw the water coming out from the fan holes in the bottom of the laptop ,, so maybe the sound chip got damaged from that ,,and if so can it be replaced ?
    The motherboard, in almost all cases, can only be repaired by the motherboard vendor or by a facility that has the equipment to work on SMT boards. In practicality, if you could get it fixed and that's a very long shot it will cost more than a new board.
    If everything else works ok, use a USB connected sound card.
    "here's something i forgot to mention" just the most important part ????
    Mike, just a "small detail"
    Jack
    Jack
    Just hope it wasn't beer !!!
Laptop fan sound in General Support
Hello, I bought a laptop 2 weeks ago and the fan was really silent until now (I always thought it is not running), and today I started hearing it, it is not running at full speed like when playing a game or using a demanding software, however it is quite loud and the buzz is really annoying when...
hi, I have an Acer Aspire V5 laptop.It has a celeron cpu,and is a basic small laptop. I listen to video news online,and i have not installed or uninstalled any software prior to the problem of no sound in videos since it last played back video with sound. I have tried to play the same video...
I tried to play songs in windows media player but it showed some error. Then i switched to VLC just to find out that there is some problem with the sound. When I clicked on the volume icon to see if the volume levels are ok, I found the computer icon, which appears there to be like as if there is a...
Erratically the sound (which is not always available) will accentuate to a high-pitched scream which necessitates closing the ears and turning down the volume control which is not maximal. With the speakers volume control at about 30%, tapping on the betzel or the screen is greatly ...
ASUS Laptop Sound Drivers in Sound & Audio
Hey guys, I've been helping my friend troubleshoot over a combination of phone/Teamviewer and cannot for the life of me figure out what next I should do. She's using an ASUS K55N-DS81 laptop, new from Amazon. It's running Windows 8 64-bit with 4GB of RAM. Main problem: her audio doesn't work,...
I have problem with sound on my laptop after I download windows 8 on my laptop. :( I could not hear any sound at all. my laptop model is dell inspiron 1420(old model) and it previously run windows xp. why is that happen? is it not compatible with my lappy or else? can you help me to solve this...
Hi, I've just got my Windows 8 through Dreamspark Premium. I was using windows 7 and did a clean install of windows 8. After installing windows 8, there's no sound from my speaker. Sound only works with earphones. What should I do? My laptop: Asus N53J **UPDATE** I went to the asus...
