Sound on Sony Vaio plays and then stops until restart
    Recently the sound on my Sony Vaio will play initially, but afterwards won't work. It doesn't say it's muted and the little green part that shows sound in the speaker area also doesn't appear when something is playing. I have tried to test the speakers to see if that plays sound but when I do it says that they are being used with another application and to close it before I try to test them, even when nothing else is open. If I restart it, the same thing will happen again. Why is this happening?
    Its not unique to your Sony. I have a Dell Vostro, and after one of the automatic updates downloaded a couple of weeks ago, the sound started doing exactly the same thing, i.e. works intermittently. Sometimes re-booting sorts the problem out, but sometimes it doesn't. Three of my colleagues with the same model laptops have experienced identical issues, so this is clearly a Windows 8 / 8.1 thing - which I wish they would fix, and quickly, because I'm becoming very irate with it.
    mz132 - have a look at the thread titled "No Sound - the device is being used by another application" No Sound- The device is being used by another application
    I didn't read through all 10 pages worth but on page 9 there is a fix - its to do with one of the updates. I've tried it and so far so good, but as its an intermittent problem, it may be a while before I can confirm whether the issue is sorted or not.
    Thanks for that, I've tried looking around but haven't found any other issues that were the same as mine. I'll look at the thread now, hopefully it works, having to constantly restart my laptop is getting tiring! Similar problems have been to do with updates so it could easily be that
Sony vaio VGX-TP20E in Installation & Setup
Hello, I have a Sony vaio VGX-TP20E. I put the win 8 disk into the computer and setup up the startup to boot from optical drive. But it skips it and starts up win 7 like it normally does. How can I install windows 8? The first time I did that win7 had some kind of virus in it so I went to the...
BSOD on Win 8.1 Sony Vaio in BSOD Crashes and Debugging
Hello, Random BSOD s started to show up on my laptop. The laptop came with win 7 and I installed win 8 to it afterwards. I have recently updated the OS to Win 8.1 and had 3-4 BSOD s in a day (driver_irql_not_less_or_equal netio.sys) Any help would be appreciated. Kind regards.
sony Vaio windows 8 in General Support
Hello....got a Sony Vaio windows 8....and noticed it has only C disc......so in case i qould like to format the laptop in the future,all data inserted would be eraSED,as it will format all Data C.....is there any way to open a new DATA D DISC?
Sony Vaio Pro 13 BSOD (I think) in BSOD Crashes and Debugging
Hi all, I have just recently got myself a Sony Vaio Pro 13 and I think I am having issues in regards to a BSOD. The symptoms seem to be related to power/standby but could be wrong. Yesterday, I shut the lid and went away. Got back from lunch and realised the fan was on full-speed while the...
clone HDD Sony Vaio Tap 20 in Performance & Maintenance
I have a AIO Sony Vaio Tap 20 that I really like, but I want to run off of a different HDD that is a hybrid drive (SSD + HDD) to increase the responsiveness. I have cloned the drive using Macrium's Reflect, but the drive won't boot. At power up, it says "a required device isn't connected" and I...
SONY VAIO drivers in Drivers & Hardware
Can someone help me with finding Sony Vaio VGN-FW130E drivers for windows 8? My laptop model is not supported for win8 in sony's support...
