No sound windows 7 - restored to 8.1 - still no sound.
    Arizona
    Had windows 7, sound worked for quite awhile with my toshiba laptop. Installed the realtek driver and about 2-3 months later the sound stopped working. When plugged into TV w headphone jack it works (at least the last time I did this). I unplugged and the sound worked again for about 2 days and then mid-song cut out and have not worked since. Any suggestions? Have checked on the sound card etc and all is working fine (so it says haha).
    If there is an HDMI cable plugged in, Windows automatically switches the default audio playback device from the "Speakers" (RealTek) to the HDMI Audio. If this is the case, you must manually change the default audio playback device to the Speakers. This is done in the Sound Panel, Playback section.
    Arizona
    Mine has anyways automatically switched back and when I go to that section of shows that the hdmi is my connected and it should be coming through the speakers.
    The "normal" operation is for the "Speakers" to be the default audio playback device. When an HDMI cable is connected it automatically changes the default to the HDMI. When The HDMI cable is disconnected it automatically switches back to the Speakers.
    Make sure you have both the RealTek and ATI HDMI drivers from Toshiba
    Drivers & Software Support | Toshiba
    Arizona
    If it automatically switches back to the speakers, why would I need to manually need to switch back to the speakers? And okay I will download the hdmi driver. I have the latest Realtek studio) audio driver.
So, I was playing a game and then suddenly my sound dropped. After it happened I tried restarting my computer and nothing happened. So now when I put my sound on 100 it sounds like 35. Can someone please tell me how to fix this, thanks.
REALTEK AC97 sound driver installed Working fine!..showing status working but no sound:cry:..after updating PC to win 8..worked well for Win 7..Need Help..:zip:
