Headphones not recognized
    Hi, my computer doesn't recognize my headphones. The speakers work fine, the headphones work on other devices. They used to work on this pc too, but a few hours ago my friends and I were trying to record something with a mixing table and they had to change a few things for it to work. I have no idea what they changed and I don't know what to try to fix it... where should I start?
    Try the System Restore and restore the PC back to an available restore date that is BEFORE whatever was done.
    System Restore will not delete any user data or e-mails.
    System Restore can be accessed from Start/Programs/Accessories/System Tools.
I have an older Dell machine that I plan to use as a backup server for my family. It has 2 SATA HDDs, 1 IDE DVD drive, 1 IDE HDD The SATA drives are recognized in BIOS. The IDE-DVD and IDE-HDD are not. Interestingly, when looking at the folder structure in Windows Explorer, all the devices...
Headphones problem in Drivers & Hardware
I have a problem with my peadphones .I plugged in the headphones and my windows it's tell me the are not plugged in. I instal an audio driver and they work but I reinstal the windows and I not whant to instal an audio driver.It's any way to have the headphones to work without an audio driver?
I need to use StereoMix and my headphones built in mic at the same time. The problem is IF StereoMix is enabled, only the PC's internal Mic is activated. I cannot activate my headphones mic unless i disable the StereoMix device first.
Headphones Problem :/ in General Support
Well my speakers do produce sound , but my headphones do not produce even the smallest amount , NOTHING. In windows 8 professional they don't work , but in windows 7 ultimate they do work...Anything like a help ? Maybe the headphones driver? I've got TURBO-X headphones , they have got 2 jacks or...
Headphones Not Working... in Sound & Audio
First of all my speakers DO PRODUCE sound but when I plug - in the headphones , they do not produce sound at all...Before some1 says go to r1ght click on the audio thing and properties from there to Enable it , I'll have to tell you Headphones aren't even existing there... I don't know what to do...
No sound with headphones? in Sound & Audio
Hey guys, I have the consumer preview Windows 8, No problems with sound initially until i plugged in my headphones. No sound at all, at first i thought the headphones where broken so i tried 3 other pairs of earphones and still nothing. Anyone have any ideas as to whats going wrong?
No sound thru headphones in Sound & Audio
On my home-built PC with dual-boot XP and Win8 RP, I can't get any sound thru headphones connected to the tower case's front headphone jack. I get sound through the speakers built into my display, which is connected to the mobo on the case rear panel. Sound comes thru headphones fine in XP. ...
