Built in microphone does not work
    windows 8.1
    Hi,
    I have a new windows 8.1 laptop and my built in microphone does not work. When I plugin an external headphones that includes microphone, it works.
    I have checked the Device Manager and the microphone is enabled. I checked and the driver is updated.
    Any idea what is wrong?
    Thanks in advance
    More details:
    Driver details:
    Screen shot of the microphone state without headphones
    Screen shot of the microphone state with headphones
    Laptop - Asus R510-XX173D. Windows 8.1. i7-4500U
    The first thing I notice is you do not have the driver for the sound chip in the PC. You only have the generic, basic function, Windows installed "High Definition Audio Codec". Although that may or may not fix your problem, the first step is to get the correct sound driver.
    Check with ASUS for the correct driver. I can't be sure as they do not list the exact model you list, but the 510L that I looked at listed RealTek for the sound drivers.
    And you can find them here too: Realtek ,with it you will get nice utility in the Control Panel to be able to make precise settings.
    windows 8.1
    That solved the issue
    Thanks for your help - I just installed the Asus driver and the microphone is now working
    Thanks!
    Quote Originally Posted by omeromer View Post
    Thanks!
    Perfectamente.
    Great. thanks for the feedback that you got it working.
Hi Everyone, My friend has an Asus laptop and he had some problems with his keyboard. So he sent it to Asus for repairs and what he got back was a perfectly fine laptop with an erased disk drive. So he had Windows 8.1 re-installed but one of the things he noticed was that his One drive...
Alright guys, I have just refreshed my pc because I was having numerous problems with it and it turned out to be a bad stick of RAM. However, now I am having software issues. Whenever I try to make a call on the desktop version of skype, the program crashes. Whenever I try to open HP support...
I just got myself a brand new PC with Windows 8. My problem is getting my mic to work the same way it did with my laptop with windows 7 64 bit (Worked perfectly, microphone level at 47 and boost at 10db). I've tried everything, and even with microphone level at 100 and boost to 30db its just...
Solved Microphone in Sound & Audio
So i Just bought i new Mic for my gaming channel. And it doesn't work on my pc. It works on my dads windows 7 but not on mine i can't get my mic to work It Says i have it enabled but i can't But it doesn't pic up any sound at all i really need HELP :( 26062 26063 26064 26065
I have an HP 2000-2b10CA and I bought it FIVE DAYS AGO!! I was checking if everything worked so I shot a video and when I played it back I heard nothing! Then I found out it was my mic! I searched online and a lot of people told me to go to the settings and set it as my default device but IT...
Good evening everyone, I recently upgraded my HP Touchsmart IQ500 from Vista Home Premium to Windows 8 Pro. Aside from the lack of a media center or otherwise out-of-the-box-inability for DVD playback I've been enjoying the change. I solved the DVD problem with VLC, but I cannot figure out how...
Hello, I have just installed Windows 8 Professional edition alongside Windows 7 Professional, however I cannot use my built in monitor when within the normal mode of Windows 8, Instead I have to use an external monitor (I'm currently using my TV via HDMI), however, in safe mode I can use my...
