Solved Built in microphone does not work
omeromer
Hi,
I have a new windows 8.1 laptop and my built in microphone does not work. When I plugin an external headphones that includes microphone, it works.
I have checked the Device Manager and the microphone is enabled. I checked and the driver is updated.
Any idea what is wrong?
Thanks in advance
More details:
Driver details:
Screen shot of the microphone state without headphones
Screen shot of the microphone state with headphones
Laptop - Asus R510-XX173D. Windows 8.1. i7-4500U
    windows 8.1
    Asus R510L-XX173D
    i7-4500U
The first thing I notice is you do not have the driver for the sound chip in the PC. You only have the generic, basic function, Windows installed "High Definition Audio Codec". Although that may or may not fix your problem, the first step is to get the correct sound driver.
Check with ASUS for the correct driver. I can't be sure as they do not list the exact model you list, but the 510L that I looked at listed RealTek for the sound drivers.
And you can find them here too: Realtek ,with it you will get nice utility in the Control Panel to be able to make precise settings.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
That solved the issue
Thanks for your help - I just installed the Asus driver and the microphone is now working
Thanks!
    windows 8.1
    Asus R510L-XX173D
    i7-4500U
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
Great. thanks for the feedback that you got it working. :thumb:
