No sound from subwoofer in Windows 8.1!
    Hello everyone, I've just got my new PC and I've got a problem with my new audio system.. I have a 2.1 Speaker system and I don't hear any sound from my subwoofer. I've looked for the problem on Google, I tried to update my drivers, I tried almost everything. A little help would be welcome, thank you!
    Specs:
    Do you have separate input to subwoofer and did you check "Enable Bass Management" ?
    Yes I did checked the Bass Management, but still the same problem. I don't really know what you mean with separate input to subwoofer, I have an Trust tytan 2.1(I know..)
    Just looked at it, it has only one 3.5mm stereo jack to connect it to Green connector on the computer. Real 2.1 system should have a separate one that goes in the Black jack in the comouter for separate control. this way only bass control is on the speaker itself.
    You mean I can't use this subwoofer at all?
    Quote Originally Posted by KnightZXC View Post
    You can use it but not control it separately from the computer. There's a button in the back of it for that.
Had windows 7, sound worked for quite awhile with my toshiba laptop. Installed the realtek driver and about 2-3 months later the sound stopped working. When plugged into TV w headphone jack it works (at least the last time I did this). I unplugged and the sound worked again for about 2 days and...
I setup a subwoofer to run from the pc from the orange hole to the sub via a 3.5mm to rca cable. I can't get it to play sound from any other program other than pandora, battlefield and youtube. VLC, netflix, mediamonkey all ignore the sub and don't use it. My speakers are connected to the computer...
I run a 7.0 speaker system connected in multi-channel analogue mode to my Creative X-Fi Titanium. I set my speaker settings on Windows 8.1 disabling the subwoofer and checking the full-range speakers checkbox to allow the low frequencies to be handled by my satellite speakers. I've made no...
asus external subwoofer in Sound & Audio
hi guys! i just want to know if the asus sonic master external subwoofer is compatible with other laptop lie lenovo g580? because my friend gave me this subwoofer and connect it to my lenovo laptop.but the sound coming out is very low.is there anything i can do? please help guys..thanks in...
Hello, I m new to this forum so excuse me is there is a link similar someplace else. my computer is connected to my samsung tv and there is a yamaha rx-v375 receiver in between the computer and the tv..now when i play a video/music/games off my ps3 which is connected to the same setup, it works...
Hi, I just bought a brand new ASUS N series today, and it came with a sonicmaster subwoofer, which unfortunately doesn't work. Whatever I play it comes out of the regular computer speakers, and I've made sure all the time that the sub was plugged correctly and at the right place (subwoofer jack,...
