No "Bluetooth device connect" sound after reformat
    Oklahoma
    Microsoft Windows 8.1 Pro
    I been having issues with my Ativ Tab 3 so I shipped it back to Samsung to fix it. Before I shipped it, It always played the sound that indicated that a bluetooth device was connected. After receiving it, I noticed it had fresh copy of Windows 8 pro on it with drivers, etc. So I updated it to 8.1 and reinstall everything and noticed the bluetooth devices no longer play the sounds when they connect. Any tips on fixing this? Tried refreshing, sfc /scannow, and redoing audio drivers.
    I don't know about a tablet, but on a regular PC, there is a System Sounds option. If there is something similar in that tablet, check that.
    Oklahoma
    All im seeing is this: http://i.imgur.com/l4RAGwf.jpg
    Nothing bluetooth related in the settings.
    Edit: Checked my Windows 8.1 Laptop and its the same thing but makes the sounds.
Hi, The initial pairing work they both identify each other and simultaneously send a confirmation passkey (6 digits) and I just press the OK button on both devices , mobile and PC (is it supposed to be that way ?). After that the connection is initiated for a few seconds and then it's lost and...
I am using a Lenovo Miix 8 tablet running Windows 8.1. I would like to add the ability to share files via Bluetooth, using the Windows 8 metro "share button" when you swipe from the right. Currently my options include: taking a screenshot and a number of other programs (which added themselves...
Hi, On a fresh clean Windows 8 image, my software driver (signed) installs fine and shows up properly in the Device Manager. However once i uninstall it , subsequent reinstalls show up as 'Unknown Device' in the Device Manager. From the device details, I find that it refers to /looks for the...
Hi! I just burned a copy of the Windows 8 Developer Preview onto a DVD. I have created a partition for the new OS (because I don't want to install over Windows 7). When Windows 7 is running and I pop in the DVD, the computer directly recognizes it as a runnable program. I'm also able to install...
