Audio service not running
  1. #61
    Quote Originally Posted by GMan View Post
    No. SMART works at hardware level. It doesn't matter what you put on or installed on the drive. You need to get anything off it that you don't want to lose immediately, then replace it.
    That means get anything you want off the drive by copying to another location, then throw the drive in the trash. Alternatively, you can keep using it and lose important data when it fails completely.
  2. #62
    India
    Windows 8 Consumer Preview
    Ohh so the hard drive was the problem all along? Any idea how long this one will last?
  3. #63
    HDD failing has nothing to do with optical drive.
    It could last until a minute from now or a long time. Either way, there is huge risk of failing at any moment from this point on.
  4. #64
    India
    Alright. So if i get a new hard drive i ll have to reinstall all the applications and softwares again right? I ll update u once i get a new hard drive. Thanks for now
  5. #65
    India
    Hey the DVD drive problem is not there anymore.. I upgraded to the Release preview n everything is working fine now
  6. #66
    Windows 8 64 bit
    G-man , i followed each step from this forum about audio problem ! yet audio not working .
  7. #67
    You can post a new screenshot of the device manager if you wish.
    You can also try to open an elevated (Admin) command prompt. Copy/paste this command then press enter:
    net start audiosrv
    If that doesn't work, try this from the following link -
    1. Open cmd.exe with Administrator rights
    2. Type in:
    "secedit /configure /cfg %windir%\inf\defltbase.inf /db defltbase.sdb /verbose"
    3. Restart your computer when the process completes
    Audio On Windows 8 Dev preview Not working Help Please!
    I'm guessing your upgrade installed Windows 8?
    Hi GMan,
    You're so great man! It really worked! Thank you
    Chichi
  8. #68
    Easy fix
    I don't know if this problem has been solved already in the previous posts, but just in case here is what I did:
    I right clicked the bottom of the screen, clicked device manager, clicked 'sound, audio and game controllers', right clicked 'cirrus logic high definition audio' and updated the audio driver software. I then restarted the computer as prompted and the annoying red cross was gone and the audio is now working fine.
    Hope that helps
Page 7 of 7 FirstFirst ... 567
As you can see I am having the problem of audio service not running. I have read a couple threads and tried to do the recovery but my control panel just freezes up. Please help with any further options. Thanks
on my HP all-in-one computer, windows 8.1 was auto installed - the sound worked fine for a day, now it doesnt - also, i cant access the control panel - how can i fix this, and where can i get a free update or audio device?
Hello, fellow... meh, I don't know. OS: Windows 8.1 Pro Processor: AMD FX-1400 Quad Core RAM: 8.00 GB Storage: 1.73 TB of 1.81 TB available System Type: 64-bit Operating System, x64 based processor ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ A...
My issue started a day or two ago when I installed a windows update. I go to watch something the next day, and no sound is coming from the computer. I double check the connections, update the drivers and still get nothing. I look around online and most people who have had similar issues had...
Solved Audio Service not running in Sound & Audio
My install went OK with the exception that I have no sound, I installed on a HP Pav m1050y Intel Pentium 4 with a Creative Audigy 2Z S sound card. In Services when I attempt to start this error returns "error 1068 the dependency services or group failed to start" Any ideas out there on how to...
