Audio service not running
  1. #21
    India
    Windows 8 Consumer Preview
    I already downloaded this chipset. I dont find my dvd drive yet even if u put in a CD or a DVD.
    And about this special tool online for removing my symantec product, where can i find it? Is the MSE provided with this windows a trial version only and will i be able to perform scans and updates?
  2. #22
    Quote Originally Posted by GMan View Post
    You can post a new screenshot of the device manager if you wish.
    You can also try to open an elevated (Admin) command prompt. Copy/paste this command then press enter:
    net start audiosrv
    If that doesn't work, try this from the following link -
    1. Open cmd.exe with Administrator rights
    2. Type in:
    "secedit /configure /cfg %windir%\inf\defltbase.inf /db defltbase.sdb /verbose"
    3. Restart your computer when the process completes
    Audio On Windows 8 Dev preview Not working Help Please!
    I'm guessing your upgrade installed Windows 8?
    thank you som much have tried so many solutions and just when bout to give up i find this . tyty
  3. #23
    India
    GMan, any other solution that u might give for my DVD problem?
  4. #24
    I quickly just re-read the thread, and it is not clear to me if you tried the solution I posted yet or not. There was a screenshot of something different.
    About this: "I tried upper filter and lower filters method and restarted the pc only to find them both no longer there." - True, they should be removed as per below.
    Can't hurt to check again to see -
    (adapt for Windows 8 obviously instead):
    1. Click Start
      , and then click All Programs.
    2. Click Accessories, and then click Run.
    3. Type regedit, and then click OK.
      If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
    4. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
    5. In the right pane, click UpperFilters.
    6. On the Edit menu, click Delete.
    7. When you are prompted to confirm the deletion, click Yes.
    8. In the right pane, click LowerFilters.
    9. On the Edit menu, click Delete.
    10. When you are prompted to confirm the deletion, click Yes.
    11. Exit Registry Editor.
    12. Restart the computer.
  5. #25
    India
    I did not understand the part about a special tool online to remove my symantec product. I have tried out installing the chipset from the link that u provided me with. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} doesnt show upper filters or lower filters at all.
  6. #26
    Ahhh, I understand now. Yes, thanks for reminding me. That is high on the list up there with a recommendation to try. I don't want to get your hopes up, but I would say there's a greater than 50% chance removing Norton/Symantec will help, especially considering other known reliable fixes have been exhausted.
    You can use Google to search for your specific product's removal tool. For example: "Norton 360 Removal Tool" or "Norton Antivirus Removal Tool"
    Download it. Then reboot the machine and while it is booting up, keep pressing F8 on the keyboard until the menu appears. Choose Safe Mode. Run the Removal Tool and reboot to normal mode Windows after completion and see if it helped at all.
  7. #27
    India
    Im not able to enter the safe mode by keying in F8. I kept pressing F8 for a number of times but it went straight to home screen. Is it necessary to remove this in safe mode? Or can it be done in the normal mode itself.
  8. #28
    Safe mode is necessary.
    Safe Mode - Start Windows 8 in
  9. #29
    India
    Entered safe mode. But when i clicked on the removal tool the following error showed up:
  10. #30
    I would upload the file you've downloaded to Jotti's malware scan to make sure its clean.
    If it is, return to safe mode and run it again. If you can't or don't know how because of what is in your screenshot, Googling will likely help.
Page 3 of 7 FirstFirst 12345 ... LastLast
As you can see I am having the problem of audio service not running. I have read a couple threads and tried to do the recovery but my control panel just freezes up. Please help with any further options. Thanks
on my HP all-in-one computer, windows 8.1 was auto installed - the sound worked fine for a day, now it doesnt - also, i cant access the control panel - how can i fix this, and where can i get a free update or audio device?
Hello, fellow... meh, I don't know. OS: Windows 8.1 Pro Processor: AMD FX-1400 Quad Core RAM: 8.00 GB Storage: 1.73 TB of 1.81 TB available System Type: 64-bit Operating System, x64 based processor ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ A...
My issue started a day or two ago when I installed a windows update. I go to watch something the next day, and no sound is coming from the computer. I double check the connections, update the drivers and still get nothing. I look around online and most people who have had similar issues had...
Solved Audio Service not running in Sound & Audio
My install went OK with the exception that I have no sound, I installed on a HP Pav m1050y Intel Pentium 4 with a Creative Audigy 2Z S sound card. In Services when I attempt to start this error returns "error 1068 the dependency services or group failed to start" Any ideas out there on how to...
