windows 8 audio settings help
    I have a toshiba satellite p75-a7200 with windows 8. When I hook up my logitech z 2300 speakers it sounds like crap. Logitech z 2300 speakers are very good speakers so this should not be happening. When I hook up my logitech z 2300 speakers to my iphone or my old dell laptop it sounds good like it should. So this makes me think that their is a Windows 8 setting that is messing up my speakers. What settings in Windows 8 do I need to change my make my speakers sound good?
    How does the built in speakers sound? How does a headset sound? The Logitech speakers should sound the same.
    The audio is handled the same as Vista and Windows 7.
    I'm not sure how to respond to this. Why would you think Computer Speakers would sound the same as built in laptop speakers and headphones? Laptop speakers and headphones can't produce good highs and lows like Computer Speakers can. Have you not seen the specs?
    Logitech Z-2300 Specs - CNET
    The built in speakers sound like built in speakers. I don't have any headphones.
    I realize built in Laptop speakers are poor, but what I was getting at do they sound about the same as the external speakers or do they sound relatively OK?
    The external speakers in most laptops plug into the same jack as the headphones. That is why I asked about headphones.
    I've looked at the specs for the old Z2300's.
    Does the Toshiba come with any audio enhancements? e.g. Dolby, SoundBlaster MB audio, etc? I have a Lenovo and it has Dolby enhancement, Dell used the SoundBlaster MB for many of their systems.
    Windows 8.1 Update 1
    Do you use any kind of equalizer (dedicated software or built into the player of your choice? Does disabling the equalizer change the sound quality? What software do you use to play your music? Are there more than one outputs (e.g. one for speakers and one for headphones)? I think in order to support you we need more info.
How to View Recently Used PC Settings in Windows 8.1 This tutorial will show you how to quickly change and "view recently used settings" that were set in your account's PC settings in Windows 8.1 and Windows RT 8.1. This can be handy to see what settings you had changed in PC settings...
Hello Dear Friends, I have Asus All In One ET2701INKI, the problem is the microphone does not work properly, It has dense distortion and echo, microphone works in other devices very well, I read many topics in many forums and I tried so many things but there is no solution, I am using...
How to Clear PC Settings Recent Usage History in Windows 8.1 Recently used PC settings allow you to quickly change and view your recently set PC settings. This tutorial will show you how to clear your recently used PC settings history for your account in Windows 8.1 and Windows RT 8.1. ...
So i am going to Reset my PC cause of different issues, and i want to export my Presets i made in Realtek HD Audio Manager, the one you make in the Equalizer and then save. I want to know, where are these save, so i can take them over to a USB drive and after the PC is reseted, i only put them back...
I was wondering what the best Beats Audio for classical Music is. My current settings are Beats:80 Treble:45 Center: 80 Space:80 Focus:80
Just installed Windows 8 and cannot find the sound settings/audio options ANYWHERE. Please help!
