Sound Blaster ZxR and Toslink - No System Volume Control
    Nearby... In an astronomical sense.
    Microsoft Windows 10 Professional
    Greetings!
    I'm having a little problem here which I wasn't quite able to solve using the official Creative Support.
    First a little explanation:
    Before installing my new Sound Blaster ZxR I had to temporarily use the Onboard Sound of my Asus Rampage IV Black Edition because of a SLI Water cooling component blocking the necessary PCI Port of the former Sound Card ( a Sound Blaster Recon3D Fatal1ty Professional ).
    Because of the cracking ( grounding loop? ) I receive during the startup when using 3.5mm jacks ( or 1/4" with the ZxR ) I stopped using them whenever possible and instead started using the Toslink connection on both the Recon3D AND the RIVBE as it electrically disconnects the PC from the Sound System.
    Now here comes the Problem:
    Using the new Sound Blaster ZxR and having it connected via Toslink to my Sound System I'm not able to control the Volume using...
    • Multimedia Keys on my Keyboard
    • Volume Mixer from the Taskbar
    • Even Muting isn't possible
    The only way to change the Volume level from now on has been by doing one of the following four...
    • Change the Volume level by Hand in the corresponding App itself, not the overall System Volume - Kind of sucks
    • Using the Hardware Dial on my Speaker System - Hard to reach
    • Switch from Toslink to Jacked Cables - Startup cracking
    Also
    • Switching the default Playback Device from Speakers to Digital Audio (S/PDIF) - Will cause me to loose the ability to run Encoders like Dolby Digital Live or DTS Connect and it's DTS Neo:PC Music Mode feature which, in my opinion, really improves my listening experience as it then uses all my Satellites, not just the front ones.
    To be honest... I'm not sure how my settings were while still using the Recon3D that allowed me to go Toslink while still being able to change the System Volume simply by using the Multimedia Keys of the Keyboard but if anyone has an idea I'd really appreciate some Information.
    Thanks in Advance.
    I have a recording studio and use Toslink's. I have to control the volume level in my recording program. There are level controls on my recording interface unit (Roland Octa-Capture) but it is for analog only.
    In a PC, when you use a digital output, that bypasses all (or most all) of the sound card as the device its feeding is the one that has the volume level control. I suspect this also applies to what you have, as it apparently works the way my Toslink works (the level control in the application program).
    Windows 8.1 Update 1
    Right click the speaker system tray icon and select "playback devices". Choose "Speakers" as your default playback device. Next you should activate "Play Stereo Mix using Digital Output" in the Creative driver settings. Now you should be able to control the volume again.
    Quote Originally Posted by altae View Post
    That did not really gave me access to Volume Controls via Multimedia Keys.
    But it's okay... I resolved to using the Volume Control of the Speaker System despite it being hard to reach...
    In the end it's not like I'm in constant need of doing so...
    And what about the software master volume/ PCM volume control? At least that one should work now if everything is configured correctly. I presume the latest drivers are installed. If you are not sure check if there is a driver update for your hardware.
The Creative Sound Blaster X-fi Xtreme Audio card works fine in Windows 8. The drivers for Windows 7 work without any problem and the Creative updater and control panel also work as they should in Windows 8. The drivers can be downloaded here for the X-Fi Xtreme Audio card - Creative Worldwide...
Hi all, Just joined up.... What I want is actually the opposite of what most people are looking for. I want to install windows 8 on my kids computer but want the volume level to be set at a certain level so the sound is not to high no matter what they do. I am able to achieve this right now...
Solved Sound Blaster X-Fi Driver in Drivers & Hardware
On Friday 10/26 I upgraded to Windows 8 Pro and found I still had the SB driver problem for the X-Fi which is not supported by Creative anymore since my system is now over 4 years old. I'm not sure exactly when this original X-Fi card came out. I tried different Creative drivers as I had in the...
