Sound issues in the front panel of the computer
  1. #11
    What's wrong with sound integrated on MB.?
  2. #12
    RWC, CA USA
    Windows 8.1 64 bit
    I dunno, I've always used cards. I guess I could pull the Audigy out and try the integrated one....
  3. #13
    You have "Realtek ALC892 codec" chip, same as mine, beats old SBs any day.
  4. #14
    RWC, CA USA
    Windows 8.1 64 bit
    OK. I'll give that a try then. :-)
  5. #15
    RWC, CA USA
    Windows 8.1 64 bit
    OK. So that's better for sure using the Realtek but now that I've got things more squared away I was able to deduce what's going on with the front panel. The input hole is loose or something. I brought up the sound properties dialog and plugged the headphones in but the default green check remained on the speakers. When I wiggled it a bit it jumped back and forth between the speakers and the headphones. Once I got it to stay on the headphones I barely moved the cable and it jumped back to the speakers! :-( Of course iTunes balked at this and refused to go after that began happening. Not sure if there is anything that can be done about the botched front input now. SIGH... always something!
  6. #16
    Quote Originally Posted by RAMWolff View Post
    Which headphones are those, not for cell phones I hope, a bit different type of connectors on them.
  7. #17
    RWC, CA USA
    Windows 8.1 64 bit
    I'm using some in ear types I use with my Mp3 player but they worked a couple of weeks ago in this panel. If there is a different connector I need then let me know - (this has the two black rings) They are Philips. I love them because they are in ear but not those new ones that go all the way in, those make my canals itch like crazy. I HATE over the ear headphones because they all hurt my ears, the cartilage gets sore after about an hour and them make my ears sweaty. So I kinda need in ear but just not all the way in and the Philips are the only ones I've found that are affordable and have good sound.
    PS. IF this is not the correct connector then is there a bit I can buy to convert them to the correct input?
  8. #18
    I asked about them because some smaller device ones like phones can have 3mm instead of 3.5 mm jacks, just a few days ago I run into that trying to use Samsung Galaxy earphones in my tower case and found about difference as 3.5mm are more accepted standard.
  9. #19
    RWC, CA USA
    Windows 8.1 64 bit
    Yea, I BELIEVE these are 3.5's. I'm actually looking at this device:
    Amazon.com: Syba SD-CM-UAUD USB Stereo Audio Adapter, C-Media Chipset, RoHS: Computers & Accessories
    It's got good reviews and ALLOT of folks have bought it for various reasons. Might be just what I need. I have plenty of USB ports.
Page 2 of 2 FirstFirst 12
Hi everyone.. I'm having a problem with my sound setup. I'm using Windows 8. I have a 2.1 channel speaker, headphone and microphone. On rear, I've connected my 2.1 channel speakers and on the front jack, I connect my headphones and microphone. The headphone works fine but Windows won't detect...
Hi. I have so many problems with windows 8.1 i have seriously no idea where to begin. First one i would like to have fixed is this damn sound, happened to me first time i installed windows 8.1 aswell, and i have no idea how i fixed it. The speakers are set to Quadraphonic, i have tried all...
No sound from front panel in Sound & Audio
Yeah so my front panel is connected to my board but im still not getting any sound Usually in the good'ol versions i would disable front panel detection from the realtek driver utility but i dont have that on this computer
I have a Gigabyte GA-F2A75m-HD2 (Rev 1.0) board and this is quite an odd one. The front port worked with Ubuntu and other Linux distros but it seems to be the opposite case with Windows 8.1. I installed the latest Gigabyte version of the Realtek HD Audio Manager but it still doesn't work. What...
Hi, Iím having a problem with the front panel audio of my new Antec One case. While the headphone jack plays sound fine the problem is that it doesnít detect when headphones are plugged in and does not mute the rear speakers. Jack Sensing is not working at all and Realtek HD Audio Manger marks...
Front panel no left sound in Sound & Audio
Hello, I've got an Z77 Pro3 mobo (Asrock) and a Bitfenix Shinobi case. I've installed the HD-audio plug from the case to the motherboards hd-audio place correctly. My problem is that the case's front panel gives sounds only to my headsets right side but not to the left side. The microphone...
