laptop is not disabling speakers while headphones connecte
    I dont get it,
    when i connect my headphones they work OK, but i can also hear trow my laptops speakers and they are not disabling themselves like they use to.
    its a huge problem and my roommate is going to kill me, i will appreciate your help ASAP
    Welcome to the Windows 8 forum.
    Unfortunately you didn't fill in the "My System Specs" so we don't know what hardware we are dealing with (and which version of Windows 8).
    Some PC sound chips, such as RealTek, have an option on whether to mute or not mute the speakers when a headset is plugged in. See screenshot below on the RealTek HD Audio Manager and the option that it has.
    United States
    Windows 8.1 Pro 64-bit
    Besides what fireberd said, you can also try compressed air can into the phone jack. Could be dust critters in there messing with the connections.
    We must have helped the user. Its marked solved.
    Jack
    United States
    Jack
    I guess so. That's good.
Dear all, I've been facing an issue with my sound lately (potentially linked to the win 8.1 update - as seems to be the case of a lot of people); I'm unable to get my sound to work, and I'm getting the following error message: "No speakers or headphones are plugged in". I've been trying out a...
Hi friends, I am using Windows 8. I am facing an issue with my sound all on a sudden. The volume icon on the task bar has a red cross on it. When I hover on that it says 'No speakers or headphones plugged in' (attachment-1). When I click on the icon I get a screen like attachment-2 which...
Hello, this is really strange. Whenever I unplug the speakers jack and plug in the headphones, the sound stops! I have to restart the application or run another one and then the sound is back. This is really silly and takes time especially when you need to restart some game. Why does it happen and...
I bought the plantronics .Audio 335 studio headphones, but when I plugged them in, it screwed up my sound. My compute'rs sound is now playing through both the headphones AND the laptop speakers. After unplugging it and trying again a couple times, I gave up and decided to just use my old...
Hi! Sorry if this topic already exist, but i think it is little different. I had this problem, i went to BIOS and enabled sound, but, when i turned on computer there was sound, but it was show as headphones, and speakers aren't plugged in. Actually is opposite, headphones aren't plugged in, but...
I have 2 speakers plugged in on m motherboards audio jacks, and my G110 keyboard has sound card of it's own built in. I was wondering if there was any way to set it up the way I want it, or something similar to it. The keyboard has a headphone mute button of its own. So I was thinking that I...
Hey back In windows 7, When I plugged in a pair of headphones the sound automatically changed to the what it was last time I plugged them in. And when I unplugged them, the sound switched back to speakers... In windows 8 (not pro version) when I plug in headphones, the sound doesn't go...
