Sound Recorder
    Sound Recorder
    Good evening to all.
    I have an Acer Aspire i7.E1-572 laptop.Windows 8.1
    Went to use the sound recorder that is included in the laptop,My granddaughter went to give a song into it and all went to plane,Played back the recording it was just perfect.
    Now the only hitch is where does it save the media I looked in all folders but failed to find it.
    Can anyone Please help.
    Many Thanks.
    San Jose - California
    1 - If you use Metro Apps, it is stored under:
    C:\Users\USERNAME\AppData\Local\Packages\Microsoft.WindowsSoundRecorder_8wekyb3d8bbwe\LocalState\Indexed\Recordings
    Where USERNAME is your user account
    EDIT: You'd need to turn on the "Show hidden files" from the folder options
    2 - If you use Windows version, then it will prompt you where you want to store.
    Many thanks.yes I have the metro apps,Got to the destination folder.
    Would it be okay to copy that folder to my desktop?.
    Thanks once again
    Yes, you can copy to the desktop or
    You can right click & hold on the folder then move to desktop then release to create a shortcut.
    Many Thanks.Good info.
Sound Recorder
Best macro recorder for Win 8? in Software and Apps
I could really use a good macro recorder. I read that some like JitBit can make the Macro into an exe. What are some good recorders both Free and commercial?
So i was playing halo 2 pc when i got a voice message. Since i always use my trusty mic headset i click play on the message and it said no playback device detected and i tried fixing it with ingame options but it didn't work! and my browser doesn't either. i tried to record my voice but mic wasnt...
Does Performance Recorder work in 8.1? in Performance & Maintenance
I am trying to analyse boot performance using this tool on 8.1 Pro. Windows Performance Analyzer I have already updated to the latest version of ADK but after rebooting it fails. I have Windows 6.3.9600 Build 9600 and Performance Recorder version 6.3.9600.16384(winblue_rtm.130821-1623) which...
How to Create a Sound Recorder App Shortcut in Windows 8.1 Sound Recorder is an app that is included in Windows 8.1 by default that you can use your PC's microphone to record audio for up to three hours per recording file. You can play back, edit and share your recordings, and use it side by...
Hello, I am wondering where the audio files are saved so I am able to upload them to a friends pc?
Sound Recorder XP in Sound & Audio
I don't really care for the current sound recorder, and I'd like the Windows XP sound recorder back because it has way more options (like echo, reverse, etc). Anyway, my question is: Is there a way that I can download the XP version? Windows 8 doesn't have the sndrec32 file (as far as I'm...
Snipping Tool, Steps Recorder in Performance & Maintenance
Hi all, I'm running Windows 8 on a new Toshiba Satellite laptop. Every time I try to use the snipping tool, the steps recorder or the sound recorder it reverts from the screen I have open to the desktop screen. Even the print screen key doesn't work, even if I press it in conjunction with ALT,...
