Sound Mix conflicting w/ Headset
    Hello! I am trying to do some recordings of video games for my friends videos but I am having issues with recording desktop sounds (in other words the game itself) anything I do doesn't work. What I am wanting to do is have stereo mix as my default recording device and have my headset as the communication but my stereo mix is currently unavailable while my headset is default. If my stereo mix is default then it works and my headset is currently unavailable. I really don't understand what is going on. Everywhere I look to fix the problem has nothing for me. I am using Windows 8.1 and have an HP Envy Laptop. I have specs written in my profile. Please help.
    Here are some screenshots of the problem.
    Normally, when recording system sounds. sounds from programs or streaming audio from the internet - basically what you hear on the PC's speakers or headphones, you need the Stereo Mix and whatever program that you use to recording must be set to record from Stereo Mix.
    It sounds like you want to do two different things at the same time, record PC sounds, but also have your gaming mic enabled. May not be able to do that. One or the other.
    Maybe someone in the Gaming section of the forum has some input on this.
    Gaming - Windows 8 Forums
    Thanks for the quick response!
    I have everything set up for what I'm trying to record with but my issues persist with the stereo mix being "unavailable". Because of this no matter what is done in the recording software (and I have tried different programs) the stereo mix being unavailable prevents the software from recording system sounds. The programs actually give error codes that point to stereo mix being an issue.
    It looks like "you can't get there from here" or in other words with the mic connected and enabled your system can't use the Stereo Mix. Do you have to have the mic connected?
    Yes, I have the mic connected.
    I still don't think it will work the way you want it to work.
    Last edited by Brink; 26 Jul 2014 at 16:25. Reason: removed redirect to post in another forum area
Bluetooth frequencies conflicting in Network & Sharing
Hi y'all, I recently bought a bluetooth adapter for my speakers, so that I can play from my phone or PC without connecting cables. Works great, except that on the PC my bluetooth mouse conflicts with the speaker -- when I move, click or scroll the audio pops and cuts out. I'm guessing it's...
I reinstalled windows 8 on my machine (installed all updates including 8.1) . The installation was in Swedish but since i prefer English as my display language I added this language, removed the Swedish language pack and changed my keyboard to Swedish layout. Now my display language is...
Bluetooth Headset Sound Loop in Drivers & Hardware
Hello guys i have a Bluetooth Headset (Xtreme XM-1200) i have connected it with my Laptop Toshiba C660-A048 but it got sound loop after 5munite when i play music, what to do ?
conflicting bios and cpu-z results in Drivers & Hardware
so i have been trouble with a few bsod problems and i was instruted to change my ram timings to 9-9-9-24 so i did and i also changed my frquency to 1333 but hen when i go into cpu-z i get different results or is this the same thanks in advance 3783137832
I'm in the market to buy a headset for chat in online gaming, at the moment game sound is through my gtx cards hdmi to my tv speakers and I want the headset for purely just voice (like Xbox). In layman's terms how would I set it up this way? A friend said he thought the game sounds as well as...
No sound using 360 headset in Sound & Audio
I am using a turtle beach headset plugged in through my xbox 360 wired controller. The device displays in the sound area but does not produce any sound when i try and test it. It doesn't even act like the test is being sent to the device. The mic however does work just fine. Anybody have any...
Headset sound quality in Sound & Audio
Hi! I would like to ask if anyone knows why is it that headset sound quality is defaulted to the lowest telephone quality, and the dropdown menu to change it is inactive? In Win7 I could change it to better (or it was deafult the best, I don't remember), but now the sound is just abysmal. I used...
