Microphone not working
    Windows 8.1 pro
    Hi, I have a Dell Dimension running Win 8.1 pro. Recently my microphone has stopped working. I have looked at other threads and none have helped. My mic does work with other computers but no with mine. When I tried to record my voice on many apps (Skype, sound recorder) but no luck. When I pull the jack out of the hole slightly it displays that the microphone has made a small sound.
    A Dell Dimension on Win 8????
    What model Dimension and what sound device and driver do you have?
    Windows 8.1 pro
    What sound device and driver do you have?
    I have a trust headset. No driver, because it is a plug and play headset.
    That sounds like a USB headset??? USB headsets have their own digital to analog conversion in the headset. Try a different USB jack , if you haven't already.
    Also, check the status of the headset in the Device Manager. If its not shown, check the USB section to see if there are any unknown devices listed. If there are its probably your headset.
    Windows 8.1 pro
    MY headset is has 3.5mm jack (2, 1 for mic and 1 for sound)
    Then it is not a "plug and play" headset. It is a standard analog headset.
    Again, as my initial request, what Model Dell (e.g. Dimension 5150, Dimension 9100, etc), what are you using for the sound card and what driver?
    Windows 8.1 pro
    then it is not a "plug and play" headset. It is a standard analog headset.
    Again, as my initial request, what model dell (e.g. Dimension 5150, dimension 9100, etc), what are you using for the sound card and what driver?
    dell dimension 5150
    Wow! I'm surprised it even works. I had a Dimension E510, which is identical to the 5150 (The E510 was only sold in the US, the 5150 was sold worldwide). I used to do a lot of support on the Dell forum.
    I see you have the generic, basic function, Windows installed HD Audio Codec. That's probably the best you can do with drivers for the Sigmatel audio. Dell has Vista 32 bit OS drivers, which on outside change may work. Product Support | Dell US
    Dell uses a Proprietary (and undocumented) front panel connection to the Motherboard. Not much you can do there except maybe reseat the connector. However, I suspect the problems are the fact the old hardware and lack of support from Dell. When I worked the Dell forums we saw many that had upgraded old Dimension's to Win 7 and have sound problems. Most wound up installing a PCI sound card that was Win 7 compatible. Generally Vista drivers work on Win 7 and Win 8, but not all will work. I linked you to the Dell Vista 32 bit SigmaTel driver, give that a shot and see what happens.
Hello Eightforums. Firstly, my problem is that my headset microphone is not working correctly. As my laptop (Lenovo g505s) only has 1 audio jack, but my headset has 2 cables (green and pink), i bought a 3.5mm headset splitter adapter that splits audio output to 3.5m headphone and 3.5 mic jack....
I have a Creative Fatal1ty Gaming Headset , the audio work's but I cannot get the mic to work. I have a Creative soundblaster 5.1 live soundcard and a abit fatal1ty fp-in9 sli m/b. Audio works on both soundcard and on-board sound on the m/b , but not the mic .... I know some basics to...
Hallo, The microphone on this non-brand headset isn't working due to the microphone not showing up under the recording devices. Audio is working for the headset (and anything else that I plug in ), but not the microphone. The green bars do not go up in the audio manager either when I test the...
I have a HP dv2519tu laptop. I have clean installed Windows 8 Pro wmc last week. But after installtion my default microphone is not working. I have checked everything like drivers but still there is no solution.Please help me friends as I am getting problems. Thanks in advance..Arvin
Good evening everyone, I recently upgraded my HP Touchsmart IQ500 from Vista Home Premium to Windows 8 Pro. Aside from the lack of a media center or otherwise out-of-the-box-inability for DVD playback I've been enjoying the change. I solved the DVD problem with VLC, but I cannot figure out how...
Microphone is not working in Sound & Audio
I am trying to record voice overs for videos I am making with a program called Pinnacle Studios 14. It's a little outdated but it gets the job done well. I am also running Windows 8 on a new computer. I am also using (or trying to use) a Logitech USB headset/microphone. The problem I am having is...
8 microphone in Sound & Audio
microphone not working
