Driver working properly but there is no sound output
    Problem:
    My laptop with OS Windows 8 will become no sound frequently. I try to find out the cause, and discover that the device is being used by another application, but I can't find any application using it, here is the screenshot:
    Under this situation, when I open Window Media Player, this problem will occur:
    I am sure that my sound drivers are working properly:
    When I use Windows Troubleshooting function, here is what I discovered (Ignore the Bluetooth):
    I am not sure about what is "Hardware changes might not have been detected", but after running Troubleshooting, my laptop have sound back, however, after about 30 minutes, my laptop will become no sound again, and I need to run Troubleshooting again and again to solve the problem. Does anyone know how to solve the problem completely so that I do not need to run Troubleshooting again and again?
    Windows 8.0 x64
    One thing worth a try is boot in safe mode, then delete the device from Device Manager. Reboot normally. Windows should reinstall the driver. It seems to work more than half the time.
    The sound problem you are having is caused by a recent windows update. See the other thread about this
    Go to page 6 and apply my instructions (Reply #54). This will bring back your audio permanently
    Ok. I had the same sound problem after updated windows 8 some days ago but i found a quick solution where you don t have to upgrade to 8.1 or uninstall any windows update.
    You just need to enter to the Control Panel -> security and System -> System -> Device Manager
    Then look for "sound, video and game controllers" put the cursor over it press right-click and select "scan for hardware changes"
    3 secs after that you will have your sound working again, you gonna need to repeat this procedure every time the sound is gone in your PC and till now it always worked to me.
    To be honest i found this solution in another forum days ago and i thought people here will eventually figured out the same solution but i see you didn t make it, so hope this will solve your problem for now, till Microsoft gives us a permanent solution in the next update.
    Windows 8.0 x64
    In effect it's the same as deleting the driver. After deleting the driver on reboot you will get "Windows has found new hardware" and it will install the driver. Also there's a good chance the procedure won't need to be repeated. Not guaranteed but driver deletion/reinstall works for a lot of issues.
Onboard Sound: ALC 888s external DAC/amp: Fiio E17 Connection: ALC 888s out----Optical digital cable-----Fiio e17 SPDIF in I do not get sound when I set Realtek Digital Output (Optical) as my playback device. I tested the cable and fiio e17 on my PS3 and it works fine. I tried on windows 8.1...
In my HP Compaq Presario V3000 Laptop with Windows 8.1(32 bit) version, when I play a video such as Youtube, I do not receive any audio although video is played.But Device manager shows the message for 'Sound audio contoller' as 'HD audio driver working properly'. But if I disable Sound/Video...
Intel® WiUSB USB-IFxHCI USB Host Controller driver is not working properly as there is the yellow hazard(or whatever)sign in device management...,how do i get this driver ?my laptop is a dell inspiron 15r?
HDMI Sound output issues in Sound & Audio
Hi there, new to this forum but i've been searching around today trying to find an answer to this problem i'm having. I've bought an HDMI cable to connect my laptop to TV, i've gone into the control panel and checked that "show disabled devices" and "show disconnected devices" are both...
Hi there sometimes it seems when plugging in a laptop to an LCD TV monitor the picture seems slightly larger than the screen which can be annoying as the charms or task bar can get hard to see or access. This can actually be fixed on a lot of monotors - for example the Samsung ones -- Note IT'S...
After installing Windows 8 Pro X64 was prompted to download cmedia sound driver to get m onboard sound chip to work.:( Downloaded the 64bt version, went to install and got message saying it wouldn't work with my system :shock:
