audio/sound not working after updated my windows
    After i installed windows update, i notice that my audio/sound is not coming up again. I've restarted my system countless time, and is still not coming up. Have checked the drivers and everything is ok but i can't play songs. Have tried using media player and xbox, but it couldn't play any file (xbox is saying 0xc00d11cd (0x8000ffff) error). Any possible solution to this please? My laptop brand is DELL inspiron 15R, windows 8
    I had this when i went from 7 to 8. I just deleted the Device in Control panel devices and rebooted, all worked then.
    What exactly did you deleted?
    control panel
    Device Manager
    Sound, Video & Game controllers
    I deleted all audio (in my case Realtek) by right click and uninstall, which removes the relevant drivers.
    I then rebooted and win 8 picked them all up again and installed drivers
    That was MY solution, and it worked.
    Windows update KB2962407 is also suspected of being a cause to the problem. Those that have uninstalled it are not experiencing the problem. This update applies to Windows 8 and 8.1.
    thanks Gary, never knew that
    Thanks all. Your replies really helped me, am so grateful.
    pleasure is all mine
    Toronto
    windows 8.1 PRO
    I've been having some of my windows sounds not work for some reason...so I uninstalled the realtek driver ...restarted computer...and reset audio device to default and all sounds are back again,...for how long?...I don't know...works now....Thanks for the tip!.*john
Page 1 of 2 12 LastLast
So suddenly when the my laptop sleeps or turns the screen off, the audio device gets taken over by some hidden application or the optional update was just faulty. I've been experiencing this for two days now. Check the picture for more information 45223
Okay well this happened like 2-3 weeks ago, i have an extremely annoying problem.. The sound of my computer would randomly stop working for some reason.. Not only that, but when i watch youtube the video or any video it won't load and it would literally pause or freeze. To fix this i would have...
This happened the first time I started this pc. When 2 applications would play sound, one would be almost muted. It's really annoying, but after an hour of poking in the settings it fixed itself. I updated to 8.1, but the problem is back. YES: I have tried doing the stupid "do nothing when windows...
I have a Gigabyte GA-F2A75m-HD2 (Rev 1.0) board and this is quite an odd one. The front port worked with Ubuntu and other Linux distros but it seems to be the opposite case with Windows 8.1. I installed the latest Gigabyte version of the Realtek HD Audio Manager but it still doesn't work. What...
Sound says digital display audio not plugged in . Default is greyed out. How do I enable? 1 Hour later and sooooo frustrated !
I was just using my earplugs on my Windows PC and I when I disconnected them, my audio stopped working. I have a quad-boot of Windows 8 Pro, Windows 8 Release Preview, Windows Developer Preview, and Windows 7. Sound doesn't work on any OS but Windows 7. When I play music on the Music app in...
Hi, I have already done a search on this forum to see if anyone has been having a similar problem and many do, but so far no suggestions have helped me...... My problem is I have an Acer 6920G laptop running Windows 8 (and 7 on another drive) and no matter which Realtek audio drivers I use, I...
