Sound Problem
    Windows XP
    Sound Problem
    Hey Guys
    So i have an Asus laptop running on windows 8 pro. From the past 3 days, whenever I put my laptop on hibernation and switch it back on, the speaker doesnt seem to be working. I am not able to hear anything at all even if the volume is in max.
    The only go around is to restart the laptop which is really irritating.
    Can anyone please tell me what is the problem.
    Thanks
    Roshan
    Try the below steps:
    Step 1. Press F2 as soon as you start the system to enter into BIOS Setup. Make sure that onboard sound is enabled. If that didn't work, proceed to step 2.
    Step 2. Go to Control Panel > Device Manager > Right click on the audio driver and press on 'Update' or click on 'Scan for hardware changes'.
    Step 3. Alternatively, you can also switch to your sound card manufacturer website and download the latest update, if there is any.
    Post back your results after trying all the steps!!
    Windows XP
    Hey
    So I clicked on "Scan for hardware changes" and it started working again.g
    Why did this happen all of a sudden?
    Thanks
    Roshan
    Quote Originally Posted by roshan567 View Post
    Any recently installed software or hardware device could be responsible. Consider installing software only from trusted software.
    P.S. Sometime, the audio driver itself gone damage or become corrupt and tricks similar to the mentioned can easily address it.
    Windows XP
    Oh OK. So is there any solution to overcome this problem permanently
    There isn't any permanent solution as this could happen anytime even after you've updated everything.
    Stay away from installing faulty applications, update computer frequently if not regularly, use standard copy of AV Programs etc. are the easiest possible way to stay away from such issues.
    United States
    Windows 8.1 Pro 64-bit
    The solution is to update to 8.1.
Sound Problem
HP laptop No sound problem in Sound & Audio
hey all i have a hp pavilion dv6-6150us ,,i was on youtube and suddenly the sound stopped working ,,no sound coming out from the laptop speakers ,, my on-board sound card is IDT ,,i downloaded the correct driver fro hp site ,,but it wont install ,, showing an error that the hardware detected is...
Hi everyone, When connecting my PC to my TV through HDMI cable sometimes the playback device does not recognise my TV. While the picture on my TV is great I don't get sound. Sometimes it works. I am not sure if this has to do with the cable ( its a good HDMI cable though) or with the graphics...
Problem with sound settings in Sound & Audio
So i just changed my sound settings(i dont know how) And now it is so. I have headphones as a laptop normal speakers(usb headphones) and when i unplug them i dont hear anything. If i plug my speaker system to headphone jack the speakers doesnt work. so can someone help me getting my settings...
Hi, I would ask you to help me with one very annoying problem. Approximately every 10min my win8 do a sound. The sound is little bit like when you connect something to usb port. I donīt know how decribe it... itīs sound like "hello something is new" :D Everything works well and...
Sound Problem in Sound & Audio
Hello i have a problem in the sound In w8 when i start the computer after a shut down, the sound doesn't work but if i restart the computer it works fine, it means every time i have to restart to have the sound working any idea?
I have problem with sound on my laptop after I download windows 8 on my laptop. :( I could not hear any sound at all. my laptop model is dell inspiron 1420(old model) and it previously run windows xp. why is that happen? is it not compatible with my lappy or else? can you help me to solve this...
Solved Sound Problem in Sound & Audio
If you have issues with sound follow guide Just update your windows 8 Install realtek drivers for windows 8 Realtek Problem Solved :thumb:
