Audio Issue in Win 8 CP x64
    Kolkata, India
    WINDOWS 8 Consumer Preview x64
    i'm getting a crackling noise / robotic sound from my 5.1 speaker connected to pc via 3.5mm audio jack ... i'm using win 8 CP x64 ... motherboard has inbuilt audio chip by VIA ... audio codec - VT1708S .... though i'm using the latest driver ver. (v9.8), it can't solve the issue .. tried running it in win7 compatibility mode but to no avail (though the HD Vdeck is running 'n' i can access the settings from UI).... strangely it was working fine in win8 Dev Preview x64 .... the main prob. is that w/o VIA audio driver, i can't get front panel audio output via headphone ... i uninstalled it .. now the audio is fine with default microsoft hd audio ....
    pls help if anyone can solve this crackling audio issue with VIA audio chip ....
    Hi,
    First try updating your wireless adapter driver from the chipset maker's website. (VIA, Realtek, Broadcom, Intel, Atheros)
    If that doesn't help, try updating the motherboard bios version.
    Kolkata, India
    ok. i'll see if it works ...
    but what is the connection between wireless driver & audio ?
    P.S. i dnt hv any wireless adapter ....
    Kolkata, India
    On the page you linked to is a bios revision from February of this year to install.
    Also on your linked page is the newest audio driver. After the above is tested, install the audio from there to make sure this is the version Windows uses. It's also a good idea to check that all the drivers from that page are installed.
    Other than that, VIA audio is definitely seeing its issues on Windows 8.
    Windows 8 Consumer Preview
    Joygr11, it's not just VIA audio. People with Creative devices, myself included, are having the same issues. We will probably have to wait for various drivers to be updated by each manufacturer.
    Kolkata, India
    ok ... so we hv to wait ...
    WIN8 CP
    Quote Originally Posted by JOYGR11 View Post
    I have the same motherboard and am having the same problem. 5 different systems all having issues. 5 systems say bye bye to WIN8 CP. No other Beta has given me this much grief...
    Hi there kramvk. I've seen something that VIA is definitely working on a beta driver for Windows 8. I don't think it will take long for it to be available.
    Orbiting the Moon
    Windows 10 x64
    My hp laptop scared the heck out of me after shutting down: big explosive-crackling noise from the speakers.
    I had some issues with IDT high definition audio not installing properly: very notorious by now, it always had the same problem with linuxes but this is also with Windows 8 now.
    The drivers that hp gave are for Vista and work only in Win7: in Win8 CP (x86 and x64) sound doesn't work with the same drivers.
    The machine is: hp dv7 3100eb.
    I'm gonna stick to Win 7 on this laptop until new drivers are available (don't wanna hear those explosions at shutdown again)
    Thanks
    Hopachi
Hello all, I just installed the Shark007 Codecs and reboot the PC. Because, I need to play.MKV video files. I didn't change that plugin settings. Now when I play the AVI video files which has dual audio (two languages), now Windows Media player automatically playing both audio sounds. When I...
Recently I decided to go ahead and update to the Windows 8.1 version of the Realtek HD Audio Driver. I procrastinated because it told me I'd have to uninstall the original audio driver and I knew it would take a while to do everything needed. It didn't help that after uninstalling the original...
Audio routing issue in Sound & Audio
First of all, i'd like to mention that while I'm fairly tech savvy, I know next to nothing about audio stuff. Now, I have an Xbox 360 that i connect to one of my computer monitors via HDMI cable. I'd like to display on the monitor, but have the audio routed through the monitor, to my pc, where i...
SoundMax audio issue in Sound & Audio
I put Windows 8 Developer's Preview on this computer a few weeks ago and have not had any issues 'til yesterday. I had no audio. I checked the drivers, checked the cables, speakers, powersupply (for the subwoofer/speakers) and couldn't find anything wrong. Except, no audio (but I didn't...
Hi, I am facing a crackling audio issue since installation of Win 8 CP. I have a Creative 5.1 VX Card and have updated also latest Win 7 driver as available from Creative 's Website. I also disabled on-board audio from BIOS. but still there is no luck with crackling of audio. Creative SoundBlaster...
